Question about Friedrich Dehumidifiers
Friedrich dehumidifier continuous pump stopped working
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Friedrich dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
SOURCE: de500p dehumidifier pump stopped working, help!!!
I only got as far as disconnecting the filter between the small water bucket and the pump. I was able to get the pump working again after I cleaned the water bucket and filter by flushing them repeatedly with fresh water. The lines after the pump contained cloudy water, but I figured since the pump was able to push it out past the pump already, it shouldn't cause problems this far down. It saved a lot of time and hard work not having to disconnet the rest of the tubing or take the water bucket off. I also realized if I disconnet the first water collection tubing from just under the front panel and point the open end down, all the water in the bucket flows out. This part is so easy to get to. Just pull out the big collection tank and it's right there on the left toward the back. I can do this every week! Maybe then nothing will sit long enough in the small water bucket to turn into any kind of filter-clogging material.
Posted on Apr 22, 2010
Hi. My dehumidifier stopped working. It powers on, but does not do anything.
Check if the full light is lit. If so check that the float switch is free.
On page 5 step 3 they discribe how the float switch needs to be free?
http://www.sylvane.com/media/documents/products/friedrich-d70bp-dehumidifier-owners-manual.pdf
Jan 16, 2016 | Friedrich Dehumidifiers D70bp
Unit forms ice on back coil. Please advise
The freon in the unit is low. You probably have a leak.
Jul 13, 2014 | Friedrich D40 Dehumidifier
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
Need container
The part you're looking for, the "Tank Assembly" is available from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282735&modelsID=122115&typeName=dehumidifier
It's Friedrich Part # 4839A10002B Hope this helps you.
Jun 18, 2011 | Friedrich D30 Dehumidifier
Light says "bucket full" but
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 27, 2011 | Friedrich D65A Dehumidifier
My D50C friedrich dehumidifier does not work. It runs - but will not extract the humidity from the air. It has only been used approx. 2 summers - no more - because last summer could not even run it. It...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 20, 2011 | Friedrich D50C Dehumidifier
Dehumidifier blows breaker
It sounds like the compressor has gone bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 24, 2010 | Friedrich D40 Dehumidifier
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
Dehumidifiers Logo
198 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
