Question about Dell Vostro 420 Desktop Computer
Will not start
Had ower failure
  • smor4u Jan 15, 2013
    IS THERE A RESET OR FUSE?
  • Official Brand Answer
  • 560 Answers
Smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355will not start - bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jan 15, 2013
E.PU error
E.PU is a general power stage failure.
Without knowing the part number of the actual inverter with the problem it is difficult to speculate what the actual problem is.
One thing to do is to check if the fan is operating. Some of the older F5 inverters utilized a feedback loop so that the inverter could tell if the fan was functioning properly. If the fan was not functioning the inverter would trip into E.PU.
May 26, 2014 | Inverter KEB COMBIVERT F5
Reset abs light
Go to your dealer. If the ABS light is on, there is a definite problem with your ABS system that could result in a loss of braking ower or abnormal braking. This is not a do-it-yourself fix for most people and defeating the light just means that the problem is still there. Failure to fix the problem could end up in a severe accident when you need the brakes the most!
Nov 14, 2013 | Land Rover Freelander Cars & Trucks
My toshiba p10 wont ower up at all ...NOTHING with or with out battery or cord totally dead .battery went dead when i was useing it and i tried to lug it in to the wall and it just kept on loosing ower...
Have you tried power up the Laptop without the battery installed? Remove the battery and plug in the charger, now Turn On the laptop, if there's no internal problem, it should power up which means your battery is bad, you'd need to replace it.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jan 14, 2011 | Computers & Internet
Need a ower manuaal for 459rog laptop
You can obtain user/owner guide manual and technical specs of your gateway in the link below.
Please leave feedback
Thanks
http://support.gateway.com/s/Manuals/Mobile/8510056.pdf
Apr 28, 2009 | Gateway 450ROG Notebook
Wont turn back on
Is your TV a panasonic? If so its the error for convergence failure.
Apr 27, 2009 | Televison & Video
I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Mar 21, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Sony KP53XBR45 no picture and sound/problem is high-volt shutdown immediately
Check the soft start system within the ower supply. also check se 135 and the electros .
Jul 07, 2008 | Televison & Video
Open Questions:
Fixed amber light - start,shut down itself and restart itself Hello, Yesterday morning, I have installed a second screen linked to my graphic card. I tried to install a 3rd screen on the VGA motherboard, and it didn't work so I take it off. I could work on the computer with the 2 screens all day long. I left my office and the screensaver started. When I came back, I couldn't started my computer and my screen didn't light on after moving the mouse or writting on the keyboard. Then, I shut down my computer to restart it. Here is the problem. 1) The power light was fix and amber, the ventilation works. 2) 2-3 seconds later, it shuts down itself for few seconds 3) And it restarts itself. However, I still have the fix amber light and the screen is not activated. I checked the wall plug, I reduced the number of device on the trailling socket. I removed and reinstalled from the motherboard the RAM memory card and my graphic card. I tried with only one screen. But I still have the same problem. Do you have any ideas about what the problem could be: - Is the motherboard over? - Is the graphic card over? - Is the power bloc over? How could I evaluate which component is not working correctly? Thanks for your precious help. My configuration : - Intel Core 2 Quad Q8200(2,33GHz,1333MHz,4Mo) - Windows Vista - Cordon d'alimentation : Européen 2M - Carte graphique : 256Mo DDR2 ATI Radeon HD 3650 (pleine hauteur,sortie DVI/HDMI/DisplayPort,Double affichage)
Mar 01, 2017 | Dell Vostro 420 Desktop Computer
Dell Vostro 420 Desktop Computer   Logo
128 people viewed this question
Alun Cox
