Question about Numark Avm02 Audio/Video Mixer with Effects
Numark avm02 The Video Controls are locked / do not respond.
Hum in speakers using numark c3fx
Or an earth problem (connecting cable problem) or dirth in potentiometers or some leaking or bad capacitors
Feb 08, 2014 | Numark Industries NUMARK C3FX DJ MIXER
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
Sound quility is poor on phono side vol., E.Q, channel control are'nt responding properly sound like the sound is up to high
I think that something is wrong. The phono connectors are exclusively for vinyl turntables with phono cartridges. In case you connect a cd player or other compatible source at these connectors the sound is highly destorted and the result is terrible. Could you please clarify me what audio device do you use at the phono input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 02, 2011 | Numark Industries NUMARK M2 DJ-MIXER
NUMARK DM1002X HOW DO I USE THE CONTROLS AND WHAT EFFECTS DO THEY HAVE , ESPECIALY THE GAIN. THERE SEEMS TO BE A NOISE WHEN RECORDING
In a few words I can clarify that the gain controls are affecting the volume of the corresponding input, so that you can set the slider at the proper level. In other words you use the gain controls in order to increase or decrease the audio level of the input so that the differences at the audio level from the sources (different recording levels, different cd players etc) will be eliminated.
In case you'd like the full user manual you can follow this official link. Click on your model and at the new window make out your name and your e-mail at the form and you will get the user manual.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 14, 2011 | Numark Industries Numark DM 1200 Mixer
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
I have a Numark C2 19" mixer. I am missing one of the small screws right next to the crossfader and need some replacements. Where can I get them and/or what size are they so I can buy them at my local...
They are LIKELY metric and the best way is to remove another and take it as a sample to a hardware store.
Use a nut to find the correct size thread and then find the matching screw and right length.
Jun 11, 2010 | Numark Avm02 Audio/Video Mixer with...
Did not get a manual do not know how to set it up
You can download the manual here:
http://www.numark.com/contentmgr/showdetails.php/id/1147/tt/5
Oct 03, 2009 | Numark Avm02 Audio/Video Mixer with...
Numark Avm02 Audio/Video Mixer with Effects Logo
46 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
