Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Appears to be stuck in auto defrost mode
Freezor totally defrosted and refrigerator is not cold. Compressor sounds like it is on. We hear a clicking sound every so often. Tried uplugging and plugging back in. Compressor starts but no cold air.
  • KBOEHME Feb 28, 2009
    I have the same problem with Model LFD22860SW, not stainless (white). Sears just charged me $80 bucks to tell me it will cost $900 to fix...on a 2 year-old $1,600 refrig...does anyone know where the PTC Relay is located...can't get a repair manual online.
  • 306 Answers
Your relay that is attached to the compressor is going bad. It is called a PTC relay. The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Jan 24, 2009
Gnev120w Made a noise, now not freezing.
the fan only controls air circulation. not the function of the motor. sounds like ur fridge is stuck in the defrost mode? check ur cold control thermostat with a multi meter for continuity. the fan does not run while in defrost mode, u can manually check ur defrost timer in the fridge by sticking a small screwdriver into the hole underneath it, and turn clockwise till u hear a click u should hear the fan and compressor come on if not turn 1 more click?
Mar 19, 2015 | Beko Refrigerators
Freezer is warming- up to 24 degrees now. something is running- should i unplug the freezer to keep the defrost fan from coming on until repairs can be made?
the fan is not a defrost fan? it helps to circulate the cold air into fridge and freezer. so when the fridge goes into defrost mode the fan and compressor stop running. if ur getting constant warm or heat? I suspect ur defrost timer is not coming out of defrost cycle? the heat is only suppose to last up to 20-30 minutes then back into cold mode? hers a trick u can use that may get u back into cold mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? if its stuck in defrost , it will now come out of defrost and u should hear the fan and the compressor come on, hope this helps let me knoiw if u have any more questions
Mar 16, 2015 | Refrigerators
Refrigerator not cooling; Freezer not freezing.
first do u hear the compressor running? any clicking sounds? cold control may be bad? stuck in defrost mode? do u hear the fan running? u can manually take it off defrost mode by placing a small philips screw driver into the tiny hole underneath it the ( cold control thermostat), and turn it slowly till u hear one click this will take it off the defrost mode. if ur problem is the cold control. if that does not work u may have a bad compressor relay and can do a 3 in 1 hardstart and it should kick back in and work agin
Mar 10, 2015 | Refrigerators
Maytag 51105349JA refrigerator top freezer snowing up and won't stop running
Defrost thermostat, defrost timer or defrost heating element is bad. Because of that the evaporator is clogged with ice and the cold air cannot get to the fresh food section. Therefore the thermostat control doesn't get cold enough to turn off the compressor. On the other hand the temperature thermostat may be bad and stuck inn the on position causing the ref to operate continuously thereby defeating the defrost cycle. Uplug the ref and allow it to thaw completely. (24hours). Then while its quiet... turn the thermostat to OFF or 0 and then to the coldest setting and listen for a click sound. No click sound means bad thermostat. Later after thawing plug in refrigerator and observe function after 2 hours and check for cold air flow to the fresh food section. If the refrigerator appears to be okay... the problem is a defrost issue. Most typically a defrost thermostat is bad, but when behind the freezer panel is a good time to perform an ohm/ continuity check on the defrost heating element.
Feb 08, 2014 | Maytag Refrigerators
Still not getting cold
First, if the compressor doesn't run, it'll never get cold. You didn't say if it ran or not.
The defrost circuit is *designed* to cut the compressor out of the circuit during the 2 - 3 times (8 to 12 hour intervals) each day it goes into defrost mode. The compressor will remain off until the defrost temperature sensor (hidden in the freezer section) reaches 50 degrees (or so) *OR* for 20 to 25 minutes each time the defrost timer cycles on. If it is stuck in defrost mode because it failed to advance due to a bad clock motor or because of bad contacts, it will *prevent* the compressor circuit from ever being energized.
Check into this circuit and the location of this timer for your particular fridge. You should not need to worry about the defrost terminator, thermistor, sensor, heater or anything else in the *defrost circuit* at this time to get the compressor running.
I hope this helps & good luck!
Jan 27, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water running from underneath the freezor onto the floor. Water pooling in the bottom of the freezor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | Amana ABB1927DE Bottom Freezer...
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
Refrigerator was not cold, now freezer is not working either
You hear a fan running - but do you hear the compressor motor running too ? Common problems are defrost timers and refrigerator being stuck into defrost - or control board problems or faulty thermostats - Those defrost timers tend to go bad more frequently on newer refrigerators compared to the older refrigerators !
Aug 17, 2009 | GE Refrigerators
Light on in fridge but no compressor sound or clicks or fan
That dude is probably stuck in the defrost mode.
OK try this:
1. Unplug refrigerator
2. Turn Cold Control to “off (Compressor is off)
3. Plug in refrigerator
The defrost cycle has now been initiated. The DTT has a bypass/test point for diagnosis. To terminate defrost manually:
1. Unplug the refrigerator
2. Turn the cold control “on” (Compressor is on)
3. Plug in the refrigerator
The defrost cycle is terminated and refrigeration cycle resumes.
Replace the dang adaptive defrost if you cannot get any response.
May 10, 2009 | Jenn-Air JCD2389G Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
430 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
