Question about Bosch Kitchen Ranges
How do I unlock the range top on my Bosch range (M twist)
Range top is "locked"
SOURCE: Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Posted on Jan 03, 2008
SOURCE: he2415u convection range
1. Access SELECT FUNCTION menu
2. Turn knob clockwise until desired language is displayed
3. Touch start to accept a language change
To access SELECT FUNCTIONS menu, touch and hold COOKING MODE touch pad for 5 seconds
SELECT FUNCTION is displayed:
1.Turn knob to desired feature
2.Press START to choose any function, and turn knob to choose any sub-functions
3. After selecting feature, touch OFF
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Posted on Feb 06, 2009
  • 10865 Answers
SOURCE: bosch evolution range door won't lock for sef cleaning
You are correct. If the door does not lock, the self-clean function will not activate.
Spray some WD40 into the lock mechanism and let it sit over night. Then try it again.
Posted on Feb 10, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool 465 accubake gas range stuck in the "lock" mode.
Hi, Try setting it to clean, then cancel the clean cycle right away. Sometimes this helps. Please let me know.
Thanks
Vic
Posted on May 17, 2009
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
We accidentally locked our Jenn Air Slide In and cannot unlock it using other recommended means (pressing oven buttons, disconnect power). Thoughts on how to physically disable lock and/or remove door?
I used a long screwdriver between top of door and top of range. Used a flashlight to see the latch, then pushed the catch out of the way. Probably not the most appropriate way, but it worked!!
Jan 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
We have a whirlpool glass top range.auto clean will not work. get an error code e-1 f-5. door doesn't lock and no heat. range is a style 2 model
Check door latch switch. located at the rear of the range. remove back panel. I believe that the assembly includes the lock motor, with micro switch
Jan 15, 2010 | Kitchen Ranges
The door is locked and i don't know how to unlock it.
if you remove the range top screws you can lift up the top and, pull the locking rod attached to the locking lever/relay toward you to unlock
Sep 25, 2009 | Frigidaire GLGF386DQ Gas Kitchen Range
I cannot get the self-cleaning feature on the range to engage. I bought the house and the previous owner left me no instruction booklets. I do not know how to make the range door lock while it is cleaning....
Check between the Door and the top of the range. There is usually a manual lock that you will need to push to one side to lock the door so that the cleaning cycle will engage.
Jul 05, 2009 | Kitchen Ranges
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Oven Range Door Does Not Lock
Jocalo, Did you set up the time for cleaning and pushed the "start" button? Gendos
Jan 03, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
413 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
