Question about Sewing Machines
Threading penncrest model 2000
Try to thread a penncrest model 2000 sewing machine
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
  • 980 Answers
SOURCE: Threading a HG Palmer Princess sewing machine
I can help you if you can email a picture with your email address, your machine is not a recognised make drivewithken@blueyonder.co.uk
Posted on Oct 25, 2009
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
Euro-pro sew & go b410 sewing machine: Diagram on how to thread it?
Am unable to locate a picture of your machine, but the attached link is threading instructions for a 416. Perhaps it is close enough to your machine model to be beneficial:
Euro Pro 416 Sewing Machine Threading Diagram
Oh yes, one more HINT: ALWAYS RAISE the presser foot when threading the top thread!
Otherwise, search for:
Make Model threading
and see if anything comes up that is helpful.
Or try this manual:
https://www.manualslib.com/manual/918249/Euro-Pro-415qv.html?page=16#manual
Remember that sewing machines basically operate the same. Even though the design has changed over the years, the threading process and sequence remains the same.
Jul 08, 2017 | Euro-Pro Sewing Machines
Minnnesota model E : threading the machine?
Try Sears. A lot of brands were similar back in those days (because they copied or re-badged other brands), so finding a threading diagram for an old Singer would probably be helpful.
Sears Roebuck and their Sewing Machines
Minnesota Model given to sister in law
Instructions For Operating the Minnesota Model Sewing Machine Sears...
Apr 18, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
How to thread a pfaff 2042 machine
You might try contacting Pfaff Support:
Machine Support
May not be your model, but frequently machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading.
Threading Pfaff Sewing Machine Select mov
Manual:
Pfaff quilt style 2042 manual
FAQ Knowledge Base
Dec 17, 2016 | PfaFF Sewing Machines
How to thread this machine
New Home Model 532 Sewing Machine Threading Diagram
or search the internet for:
New Home + (Model #) + threading diagram
Hint: Always Raise the Presser Foot when threading the upper thread. This insures the thread will seat properly in the tension disk.
Jul 20, 2016 | Sewing Machines
How to thread.
Google it make model and threading diagram .
Mar 24, 2016 | Sewing Machines
Where can I download a free manual for a Dressmaker Deluxe Zig Zag sewing machine SWA 2000
Try searching the internet for:
Manufacturer + Model + the word "Manual"
Perhaps this will help:
Dressmaker 2000 Sewing Machine Threading Diagram
Dec 19, 2015 | Sewing Machines
How to thread an old Montgomery Ward sewing machine model 30 ? e
Search the internet for your machine make & model & threading instructions. You may not find your exact machine, but a lot of similar machines will have the same threading sequence.
Just a hint: be sure to RAISE the presser foot BEFORE threading the upper thread so the tension disk will allow the thread to seat properly.
Video Demonstration of vintage Montgomery Wards Sewing Machine built in...
Dec 05, 2015 | Montgomery Ward Sewing Machines
Need threading diagram for model #1766
Go sewusa.com for a free threading diagram.
Feb 20, 2010 | White Sewing 1766 Mechanical Sewing...
Sewing Machines Logo
146 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
