Question about Simpson Washing Machines
When you close lid machine does not goLid sensor not working
When close lid does not start
  • 5 Answers
SOURCE: The small metal piece on the lid rusted and broke
You can bypass the switch by jambing something in there and this will allow it to spin with the lid open or closed but please keep the lid closed at all times while washing.
Posted on Oct 31, 2009
appliances19
  • 11 Answers
SOURCE: Machine fills with water then will not start wash ( lid is closed
Check he lid switch and or replace it, should fix your problem.
Posted on Nov 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Machine wont start after lid is closed unless lid is bumped
Check your lid switch. The symptoms of having to move the washer lid is a symptom of a lid switch malfunction. Other symptoms may include, no spinning, no agitation, stopping at the rinse cycle and no draining. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop and compare.
If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number (located on a nameplate along the wash tub rim under the lid) if its different than the one you listed the question under so that I may be able to assist you better. I hope this information is helpful to you.
NOTE: You do not have to drain the wash tub to perform this repair.
Posted on Dec 29, 2009
tzweeb
  • 318 Answers
SOURCE: lid closing will not allow machine to operate.
check the lid hinge on the LH side. the screws will come loose and then will not always engage the lid switch.
tighten the screws and if you need to you can reach under the top where the hinge is and bend it backwards to get it to engage the switch. usually the screws will take care of it.
Posted on Jan 07, 2010
  • 1937 Answers
SOURCE: when you close the lid
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Aug 12, 2010
When I try to start my washer the lid locks, sounds like sensor is working but then lid unlocks again and sensor light stays green. It will work in drain and spin. Anyone have any ideas?
Owner's manual troubleshooting? Wild guess, catch won't hold due to wear, (not likely) or possibly some lint or trash has caught on the catch or it's mechanism. If it doesn't close properly the machine's "brain" doesn't like the imprecise position and unlocks.
Mar 06, 2015 | Washing Machines
Washing machine will not start washing when lid is lowered
ya. not a big problem it seems. here it goes
when ever you close the lid the tip of lid touches a sensor which signals the control board to start the rinse cycle.
now these many days that sensor has been in dying stage. that is why you were often closing it to let the cycle open.
now that sensor has completely dies.
just replace the sensor at the point where the lid touches the opening.
after that enjoy washing.
Jan 04, 2008 | Washing Machines
My kenmore washing machine fills up and agitates but does not spin
Lid must be closed for spin to start.
If the lid is closed and still no spin, the sensor (switch) for the lid may be bad. If you can locate it and manually trip the sensor, you may find it out of adjustment. Yours may be on the rear-left of the top of washer.
Replacing the sensor isn't too difficult or costly...but, always-always unplug the power before you work on it.
If you have determined that it is not the sensor, give the timer a little click forward. If that works...the timer may be going bad (not advancing).
Does the spin work in other wash cycles? If so, it might be bad timer.
Dec 29, 2014 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
I have a top load machine which shows LE error code despite lid is closed properly. This continues for half an hour then machine starts working again but the error resumes after every two minutes. Plz help
'LE' stands for Lock/Lid Error. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
Sep 09, 2010 | LG WFT1071TP Top Load Washer
The small metal piece on the lid rusted and broke away so now even when the lid of the washing machine is closed, the machine won't start because ti can't detect the lid as closed. What can I do?
Oct 31, 2009 | Washing Machines
Whirlpool calypso GVW9959KQO won't start
the door lid sensor is locaded infront of the machine lide smach in the front center how ever your interface control may be conpromiced.it will not take comands and will lit the door open display had one just like it.
Jan 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Avanti w798ss doest start
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Nov 08, 2008 | Avanti Top Load Washer W797
Ge spacemaker
check power at the receptacle make sure you have 240v
May 11, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washing Machines Logo
13 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
