Question about Technics SL-BD22 Turntable
How to adjust tracking force on bd-sl22 - Technics SL-BD22 Turntable
Genie trac drive
Over time, grime gets into the tracks, lubricant gums up in the rollers, and more pressure is needed.
On the ceiling mounted motor unit, there should be a pair of adjustment screws.
On my LiftMaster, they're labeled "OPEN FORCE" and "CLOSE FORCE".
These will increase the force exerted in the respective direction.
Make sure you are not adjusting the two screws that control the travel limit.
Adjust a LITTLE (like 1/8 to 1/16th of a turn at a time) and test before adjusting further.
Oct 07, 2013 | Building Materials
Tip
Select your needed subtitle and audio track while doing Blu-ray ripping on Mac
Because of the victory over HD DVD in the format war, Blu-ray disc has established its own reputation in this field. The one who does not have Blu-ray movie collections may be considered out of date. As a matter of fact, BD has become the symbol of high quality movies-high resolution, crystal image, and theater-like surround sound.
However, it’s uneasy to keep a large number of Blu-ray discs in a tidy way, especially when you have hundreds of discs. Due to this, backup them to your home server, or the hard disk of your Mac, or some external hard drives would be a good way to digitalize and store your BD collections. To backup Blu-ray movies, you need a Blu-ray Ripper, the thing is that most programs are unable to deal with BD subtitles and audio tracks in a correct way, or have audio and video out of sync issues, etc. Fortunately, Pavtube Blu-Ray Ripper for Mac is out of this category, it is professional in converting Blu-ray subtitles and audio tracks. My great pleasure to share its step-by-step process here, hope it will be of some help for you folks who are looking for such an application.
Okay, here we go.
First of all, you can download Pavtube Blu-Ray Ripper for Mac here.
Step 1: Launch this program, and load Blu-ray files to it.
You can import BD files through "DVD Folder" and "IFO File". Generally speaking, the .m2ts stream which has the longest duration would be the main movie, you can right-click on it, and then "Uncheck all", afterwards, only tick off it to convert would be OK.
Step 2: Select subtitle
Click the drop-down list of "Format", then all the subtitle info in the Blu-ray will be shown clearly, including language and stream ID, so you can select your needed language as your subtitle.
Step 3: Select audio track
Click the pull down menu of "Audio", and then the list will give you the detailed information of audio tracks, including language, audio codec, stream ID and audio channel. TrueHD audio and DTS-Master Audio are all supported.
Step 4: Click the drop-down list of "Format" to select output format
This program provides a wide range of output formats, including SD format, HD format, and videos for various multimedia devices, like iPod, iPhone, Apple TV, PSP, PS3, Archos, Motorola Droid, etc., you can select whatever format you need at will.
Step 5: Click "Settings" button to adjust audio and video parameters
All the parameters in the following window are changeable, including codec name, bit rate, aspect ratio, frame rate, sample rate, and channels. You can adjust these items to make good control of your output file quality and file size.
Step 6: Click "Convert" button to start BD ripping
Once finished, you can click "Open" button to find out the output files with your selected subtitle and audio stream with ease.
on Feb 08, 2010 | Computers & Internet
I have a denon DP-7F direct table (1989)ust wondering about the point of the arm the head of the cartridge housing is very close to the record any way to get that adjusted higher?
If the tonearm balance and tracking force for your cartridge are adjusted correctly, ignore it.
Register and download the manual for free at vinylengine.com
http://www.vinylengine.com/library/denon/dp-7f.shtml
Eeeww, page 8 says the counterweight snaps on and the tracking force is factory set. Any self-repecting turntable should have precise manual balance and tracking adjustments. Or your counterweight is not on? Either way, I'd look seriously at getting the stylus checked for excessive wear if it's tracking too heavily. The manual says 500 hours of normal use. You'll be carving up your recordings.
Maybe post the question to the guys at Vinylengine
Apr 30, 2011 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Turntable arm sails over the record as if the stylis wasn't in. I took the red cover off. thanks
Set counterweight balance until your stylus floats -- just 1 mm above your record, then adjust your Vertical Tracking Force. Vertical Tracking Force should be set according to your stylus' specifications. Today's VTF should require between 1.25 to 2.0 grams. Hope this helps.
Dec 14, 2010 | Audio Players & Recorders
How to install shure m44-7 cartridge on technic sl 1200.ive aproblem with the wt.,as i feel the shure cartridge is lighter then other cartridges do ihave to install extra wt. with the cartridge
No, you should not need to install extra weights. Adjust the tomearm counterweight (on the back of the tonearm).
Install new cartridge.
Set tracking force dial to zero.
Adjust counter weight so tonearm floats vertically. This is the balance point.
Dial in tracking force, 1 to 3 grams.
If you cannot achieve balance point then you may have to add weight between the cartridge and the cartridge mount
Oct 20, 2009 | Technics SL-1210 Turntable
My brandnew Songwriter is not playing records properly. When a quarter is placed on the tone arm, it plays fine. Is there an adjustment I can make??? Marilyn
http://www.crosleyradio.com/Manuals/CR248_Manual.pdf
I didn't see the tone arm balance adjustment in the user manual, however that is what needs to be done. At the rear of item #39, on page 10, is there a dial with numbers from 0 to 4 or 5? If so, set the dial to "0" to see if the tone arm will "balance" (like a see saw) If not, the dial assembly (which is a weight) needs to be slid either forward or backwards to achieve balance. After balancing, turn the dial to a number higher than 0 to increase tracking force..keep increasing the tracking force until it stops skipping, but no more than necessairy. To much force causes wear/damage to albums. If there is no tracking force adjustment on the tone arm, I would suggest contacting Crosley @ http://www.crosleyradio.com/Support.aspx
Hope this helps.
Aug 18, 2009 | Crosley CR248 Turntable
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
What is tracking force and arm weight for Dual 505-2 deck?
http://ortofon.de/ should give you the weight. It should also give you the range of tracking force. To get the right weight you can use a stylus balance. The electronic ones are expensive but good. The mechanical ones are not great but better than nothing. I set my turntable up with an Ortofon-branded mechanical balance for weight, and a test record for tracking force.
Apr 09, 2009 | Audio Players & Recorders
My 16" Delta band saw blade is drifting how can I fix it?
The blade guides are not intended to prevent your blade from drifting they are there to ensure proper blade path while cutting forces are being applied. There is a tracking adjustment for the upper wheel. Unplug the saw. Start with light blade tension. Turn the upper wheel by hand while adjusting the tracking knob. When the tracking is close set proper blade tension and check tracking again. You can make fine adjustments to tracking with the machine running.
Jan 07, 2009 | Delta Saws
Technics SL-BD22 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
