How to change channel to video input with out the remote
    New Friend:
  • 4 Answers
You should be able to use the menu display to MaNually select channels or to add them.. Another way is to channel all the way down to 1 and keep pushinsomtimes it will cycle threw the av's.. Or on newer TVs there is a video button that when pushed u can cycle up or Dow on the display intell the right on u want is highlighted and then press select or ok or which ever button selects I've seen it to where if u leave the one u want highlighted after a few seconds it will select for u.. Good luck
Posted on Jan 15, 2013
    Filmmaker:
    Uploaded 5 video answers.
  • 25 Answers
Bet you could pick one up from your local pound shop for a fiver or aroud that price
IBeMad
  • 85 Answers
SOURCE: powers on will not change channels or video inputs
Is your remote programmed properly? If it is a universal remote, try setting it to one of the different codes for your brand. Sometimes the power and mute buttons and things like that are the same for all different types of a brand, yet all of the channel and volume things are different. If it's the remote that came with the TV, then I would try to get a replacement, as it could be faulty. Hopefully this problem is with the remote, and not the TV. Find if this is the case by using the volume/channel buttons on the TV itself. If they work, then you can be reasurred you don't have to call the TV repairman, and you will probably be able to fix this problem yourself.
Posted on Mar 16, 2008
  • 8 Answers
SOURCE: need to put tv on video 2 mode to use ps3 and no remote
Have you tried running through the channels until they wrap around and start over again? Alot of TV's will throw the AV inputs in there before the first broadcast channels.
If not (and you're gonna hate my answer, but be kind to the messenger please!), you may have to purchase a new remote control from the manufacturer, which can be exorbitantly priced. Most 'Universal' remotes will act just like your Dish Network remote, and you will probably not be able to use any of your set's advanced functions through them.
I would recommend searching the web for the appropriate replacement remote control, you may get lucky on eBay and save a few bucks. Hope this helps!
Posted on Jan 09, 2009
  • 362 Answers
SOURCE: I lost the remote for
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
lone99star
  • 1121 Answers
SOURCE: menu keeps flashing remote control wont work, cant
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Posted on Nov 29, 2009
SOURCE: 537H-B11 For the first 20-30 seconds no response
I have the same exact problem, it's so damn frustrating.
Posted on May 12, 2011
How to change input on older model magnavox tv remote
Some of the old sets input/tv-video are only on the original remote.
If no buttons exist on the set you may be out of luck---One possible thing to try depending on age of set:
Some if you scan the channel button down below channel 2 you may find the input is on a channel for example 91-99.
Good luck and hope you get it working.
Dec 06, 2012 | Televison & Video
How do i get to the different inputs on Admiral Tv
Original remote only here---Universals are far from Universal.
Apr 17, 2012 | Televison & Video
My rca universal remote won't change the channel to video mode
GO TO BESTBUY AND GRAB A REPLACE FOR LESS THAN $13
Apr 05, 2012 | RCA Televison & Video
Can't get General Instruments cable box to search
if you have a cable box then you will not need to search for channels. Depending on the cables you are using to connect your TV and cable box, the input channel the TV needs to be on changes. Cycle through your available inputs by using the Input or Video Source button on your remote. Check each one for audio/video. Once you are on the right input, use your CABLE remote to change the channels. DO NOT USE THE TV REMOTE.
Jul 18, 2011 | LG Televison & Video
Input channel with no remote
You should be able to select the AV input with an Input or Menu button on the front of the TV.  If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
May 28, 2009 | ESA ET427E 27" TV
Cant get the tv to change from aux to reg channels
depending on the tv, some tv's you can change the input by channeling up and down. others you have to push an "input, tv/video, source or a/v" button. some tv's have this button on the tv itself (try that) or try the button on the remote. make sure you are using the remote that came w/ the tv. (because if you have a satellite remote, some satellite remotes the input button has to be programmed seperately) the problem is not exactly clear if you could be more specific steps that you are taking to try to change the input to the regular channels. i may be able to help better
Apr 10, 2009 | Televison & Video
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Video input
If there is no input button on the tv itself to change the input then you will most likly need a remote. so you can get a universal remote and follow the instructions to adapt it to your set then you can use it to change the input. (you can get a universasl remote for like 10$) hope it helped
Aug 24, 2007 | GE 31GT660 TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
