Question about Canon PIXMA iP4300 InkJet Photo Printer
Power outage=shut down
We had a power outage and the printer will not turn on. It is pluged into a surge protector and it was not running when the storm hit. We tried plugging it into another outlet, turning it on, running it from the computer, etc. Any ideas?
  • pyrade Jul 17, 2008
    Location is in canada... Samething after a power outage the printer do not turn on.. Will bring the internal power supply at work and see what's going on.
    Genius:
  • 2,985 Answers
You do not say your location- so this may not be relevant to you. If in UK - check the power cord fuse. If it is a model that relies on an external power supply- try to find anther of the same specification. Other than that presume it has died
Posted on Jul 10, 2007
SOURCE:
Zenith Pdp42t10000 won't turn on after power outage..it was on a surge protector which was still plugged in but was in "off" mode.
Connect something else to the same surge protector, and turn that on. Does that work? if not replace the surge protector.
Dec 19, 2013 | Televison & Video
My daughters xps 200 won't start, she presses the button and nothing. She has checked the surge protector that it is pluged into and it is OK... is there a reset button is there was a power surge??
most surge protectors have some sort of on/off switch and a reset button. If there was a surge then you would need to pres the reset button to get the surge protector to function again. If there was no surge then try using the on/off switch on the surge protector to see if that helps. Also try simply unplugging the power cord from the back of the desktop while the computer is turned off. This will sometime also help.
Oct 12, 2009 | Dell XPS 200 PC Desktop
After power surge, canon I9900 printer will not turn on?
You can try to power up with the printhead out, that sometimes causes it to not power up. Otherwise that machine is fried since you can't get a replacement logic pcb anymore.
Jul 30, 2009 | Canon i9900 InkJet Photo Printer
Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Jul 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp laserjet printer 2840
Most surge protectors only protect up to a certain limit. If you had a large surge, then i would say the power board in your printer has been zapped. I would suggest you purchase a new or second hand printer to replace yours, unless your willing to pay more than the printer is worth to fix it.
Another thought is that the problem could be the actual power point it was plugged into. Try plugging it in to another power outlet that you know is working.
May 14, 2009 | HP LaserJet 2820 Printer
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
Desktop won't start after Hurrican IKE power outage
the only thing i can think of is the power supply got fried that is the most common problem when it comes to the pc not powering on. Now hopefully that is all that it fried and not the motherboard my suggestion is to take to local pc repair shop and have them change your power supply or you could put it in if you familiar with how the machine is wired.
-replex
Sep 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
313 people viewed this question
Clive
Clive
old marine
old marine
Ekse
