My u3 8gb sandisk flash drive is saying ineed to format.it.. it all happened just after i formated my compter. but it is the same thing on my laptop.even tho it didnt get formatted.ni cant lose my stuff on it...what can i do?
  • 79 Answers
You have lost your stuff more than likely. You can try to use ScanDisc in applications to fix it, but possibly dead. You will need to reformat.
Posted on Jan 25, 2009
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I transferred a file onto a SanDisk and it shows up on the disk on that computer but when I insert the disk into the computer I want to copy the file to it says This folder is empty. I don't get i
What operating system is on the computer you copied the file from, the computer it's going to? Did you encrypt the flash drive? Example: if you have the drive formatted for HF+ on a Apple you won't be able to see it on a Windows box without a little help. If this is the case, plug the drive in the Windows computer format it as NTFS. Plug it back into the Apple, Apple can see NTFS, copy the file to flash drive, plug into win comp and it will see it.
Dec 19, 2012 | SanDisk Electronics - Others
I have a sandisk disk on key with a 4gb memory capacity. it currently has NOTHING stored on it yet says i only have 1.45 gb free. how do i clear this up? is there a way i need to format...
Hey gita! Formatting a Flash drive is really simple! Assuming you're using Windows, plug it in your PC and go to My Computer. Right click on the drive and press Format. You can choose either Quick format or normal format(Quick format does it really quickly but it may not yield best results). After that simply press Format and wait for it to finish.
You should have formatted your Flash drive and have your original 4GB of space restored!
Keep in mind that you may have less than 4GB(about 3.8-3.7) This is because formatting writes instructions to the flash drive.
Have fun :)
Aug 21, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 4Gb Cant Format
With your computer on and the SD Flashdrive fitted correct side UP in the USB port, go to 'My Computer' on the desktop and select the flash drive. The computer will ask you what function you want to perform on the drive and you must select 'format.' You did not say what kind of operating system you are using or I could give you more information. Let me know what happens,
Sciencewoman
Apr 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sd memory card says card can not be read why?
you can try formatting the disk. otherwise, it may be erased or damaged.
this same thing happened to me with my sandisk 8gb micro sd in my phone.
I lost everything on the disk, it never worked again , and still not sure how it happened?
maybe they zap em from satellite to make us buy new ones? LOL who knows.
more than likely if it cannot be formatted and cannot be read it's done.
p.s. did you check to see if the disk is locked?
Mar 26, 2010 | SanDisk 1GB microSD Memory Card
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Nov 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Micro 4G suddenly stopped working
just try the card with any phone wether its working or not its working just format from your phone or format using your pc because its due to virus your problem will be cleared
Jul 03, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Formatting
Hello Laurakeeney1
I would check to make sure your SD card in not Set to Write Protected, if it is not follow this link for a Flash Memory format utility that I use to fix any problems i have with Flash memory
HP USB Disk Storage Format Tool - v2.1.8
http://files.extremeoverclocking.com/file.php?f=197
Hope this Helps
May 05, 2009 | SanDisk 2GB microSD Memory Card
Formatting
Hi Dear, Same Problem Happened With Me When I Inserted 4GB M-Card In Phone, Later On It Failed To Format And Whn I Use That Card In My Card Reader On PC It Waz Showing 1.8 GB,
I Guess Yu 've To Use 'HP Formatting Tool' To Fix It Up,
Before Downloading, Wanna Let Yu Know What Happened To My Other M-Card Whn I Used It...
I Had 2GB M-Card When I Formatted It On 'HP Formatting Tool'
Later On It Waz Showing 4GB, I GuesS Itz Only Coz That Version Of HP Formatting Tool Supports Only 4GB M-Card Coz It Waz Already Mentioned On That Tool On The Dialogue Box,
One More Thing That Yur Phone Might Not Supports 4GB M-Card And Made This Mess,
Hope This Helps
Best Of Luck Dear...
Mar 31, 2009 | Electronics - Others
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
