Question about Leica Telephoto 60mm f/2.8 Elmarit R Macro Manual Focus Lens (with Rom Contacts)
Troble light stays on dsc alarm home
Trying to reset system
Battery trouble yet my battery tests ok
Posted on Apr 07, 2009
  • 26 Answers
THERE ARE SEVERAL REASONS FOR TROUBLE YOU NEED IT TO HIT THE STATUS KEY THEN SEE IF ITS BATTERYSOR PHONE LINE OR ONE OF THE TRANSMITTERS. THEN I CAN TELL YOU HOW TO FIX IT OR PROGRAM IT OUT.
Posted on Jan 31, 2009
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
Change language on DSC maxsys keypad
I can help you default the system. I got this out of the manual.
Hardware Reset of Memory to Factory
Defaults
If the Installer's Code is lost through inadvertent
programming, the only means of reprogramming the
system is by a hardware reset. If the Installer's Lockout is
enabled, there is no way to reprogram the system without
entering the correct Installer's Code.
The PC4010 can also be reset through software in the
installer's programming. See "Factory Default" in the
Programming Guide.
Note: Panels returned to DSC with the Installer's
Lockout feature enabled and no other apparent
problems will be subject to an additional service
charge.
To reset the panel to factory default conditions:
1.Power the system down by removing both AC and
battery power to the main panel.
2.Short the zone 1 terminal and the PGM terminal on the
main panel.
3.Restore power to the main panel.
4.Wait for 20 seconds then remove the short between
the PGM and zone 1.
5.The system will have reloaded the memory with
factory defaults. All modules will have to be enrolled
again. The event buffer is the only part of memory that
is retained during a factory default.
May 21, 2014 | Home Security
I have an ADT security system, the DCS alarm panel lcd5501z panel bypass motion sensors will not reset. The door and window sensors work fine when the alarm is set. but the interior motion sensors stay...
I would power down the main cabinet for 1 min. And unplug the battery in the cabinet. Most of the time this cabinet ( panel ) is located in a closet and contains the main brains of the system. Sometimes there is also a reset on the motion but when used, it can put the motion in test mode. You can also check the batteries in the motion ( if its wireless) The first thing I would do is power down everything and disconnect the battery. This resets and works 90% of the time. You might need the key to get into the box.
Sep 06, 2013 | DSC Power Series Lcd5501z 5501z Fixed Msg...
Trouble alarm every 12 hours
Here is a link to instructions to access web based control of alarm unit.
http://www.smarthome-products.com/productspecs/DSC/TL-150-Manual.pdf
Hopefully you can log into it and find where to set time server, or at least set time/date.
Aug 14, 2017 | DSC Tl-150 Ip Communicator Lan Wan Network...
I have a DSC PTD1640u and it keeps "chirping" every minute or so. I do not know how to make it stop. It came with the house I bought, so I do not have any codes or the manual for it. Please...
The DSC PTD1640U is a power supply for a DSC alarm system. Is the power supply (wall transformer) actually chirping or is it the alarm panel? If its the wall transformer, jsut replace it. If it's the alarm panel, what you need to do is find the type of alarm panel you have. It's usually on the circuit board or panel cover. Then download a user manual for that panel, just google it. Then follow the instructions to reset it or remove the alarm fault.
Jan 13, 2011 | Computers & Internet
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
Sep 22, 2010 | Honeywell 5804 Ademco Wireless Security...
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows an alarm memory stating ''panel lid''. How do i reset this alarm message?
An "alarm Memory" indicates that a zone was activated the last time the system was armed. To view what zone caused the problem press the * key (star) + the 3 key. To reset the memory simply arm the system and disarm. Hope this helps.
Apr 21, 2010 | DSC Power Supervision Relay For Smoke And...
I need an instruction manual for a DSC PC500RK home alarm system
try elitezoom.com or safemanuals.com they may have 1
Aug 26, 2009 | Home Security
Head lights stay on when you turn the van off.
try taking the neg battery cable off for 2 min and put it back that should reset the alarm
Dec 14, 2008 | 1999 Dodge Caravan
Leica Telephoto 60mm f/2.8 Elmarit R Macro Manual Focus Lens (with Rom Contacts) Logo
98 people viewed this question
Top Leica Cameras Experts
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
