Question about Fisher and Paykel DG05 Gas Dryer
Kenmore Dryer Have a Kenmore Dryer and you have to hold the Start button to keep it running. It is 5 yrs old and everything under the sun was replaced at one point. It will turn on when you press the button- and as soon as you let go- it shuts off. The vent is clear. Last time I believe Sears replaced the control panel. We did not renew the warranty. Please advise! Thank you
  • 432 Answers
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Posted on Jul 10, 2007
I have a 5 yrs old LG dyer that will not start. When I push the start button it is just making an electrical buzzing sound and if I hold the button long enough is starts to smell like something electrical...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 24, 2010 | LG Dryers
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
May 05, 2009 | Kenmore Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore gas dryer will not start model 110 72972109
check your motor relay under your control panel
Dec 23, 2008 | Kenmore 62802 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
psrao, right next to the timer under the consol is the even heat board. When this fails, it will cause this problem. This has been an issue with this model. Part number for the board is 3978949. Catriver..post back.
Jan 14, 2007 | Kenmore 73952 Gas Dryer
Fisher and Paykel DG05 Gas Dryer Logo
129 people viewed this question
Top Fisher and Paykel Dryers Experts
Craig Butler
Craig Butler
jimorris77
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
