Question about Honeywell Heating & Cooling
I just got a honeywell RCT8100 69-2336ES and everytime the furnace kicks on then goes off it waits about 5 seconds and turn right back on for another whole cycle. Can't figure out why it's doing that.
SOURCE: Thermostat seems to be working, furnace does not always turn on
i need help rplce thrmostat with a digital braueburn my furnance wont turn on no flashing lights cant reset the burner though has power what do i do shoul i reset the circut breaker that was never tripped though
Posted on Jan 26, 2009
  • 70 Answers
SOURCE: Furnace kicks on every 15 mins
fuanace may be oversized and is short cycling it heats up house to fast it is better when they run longer
Posted on Oct 04, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Posted on Dec 28, 2009
  • 2598 Answers
SOURCE: I recentally relaced an old
Hi sounds like the pressure switch is faluty try jumping out to see if it starts
Posted on Jan 28, 2010
  • 13 Answers
SOURCE: batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Posted on Feb 02, 2010
I have a hose loose on furnace not sure where it goes
your flame sensor may need to be cleaned its the metal rod in front of the burners. You can take sand paper and clean the carbon build up off of it. Do not over sand it just lightly sand it
Feb 27, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
My furnace is only cycling for a few seconds and shuting off then it will kick back on for a few seconds and turning off again .the trouble shooting said its the heat anticipator .and the problem is my...
Hi remove the front cover on your thermosat turn the power off first blow any dust of the mercury tube , you will see a round disc in front of you with small lever on it this what is called the anticipator you can adjust this moving it up or down ,
Feb 15, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Batteries died on my honeywell RTH230B replaced but furnace won't
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
Turns on and Turns off
Does the furnace burners light? You could have a bad thermostat or a flame sensor. To check if it is thermostat turn power off to furnace take thermostat off wall take wires marked r & w and connect them together then turn power back on. If furnace comes on and stays on then you need a new themostat if not it is the flame sensor inside furnace. Also check furnace filter
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Dec 06, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
