Toshiba M35X Screen has red hue
Ed Soderberg, my Toshbia laptop has a red hue in the background. I've tried a external monitor which had the same problem. Could this be a video chip problem?
Thanks
  • 43 Answers
It most likely has something to do with the video chip set your correct, try a power reset though, as simple as it is it can resolve these kind of things, remove the battery and ac adapter and then hold the power button for a minute and return the ac adapter and battery, if its still red call toshiba for warranty options
Posted on Jan 24, 2009
My Toshiba satellite M35X-S149 shows the lights and can hear it running but there is no display on the computer monitor
Hi oysertails...
Try hooking your laptop up to an external monitor...if you can see the picture on the external monitor then your lcd screen may need replacement or the lcd inverter board.
Please take time to rate me
Sep 24, 2011 | Toshiba Satellite M35X-S149 Notebook
The screen on my toshiba satellite a135-s2386 has a red hue for the second that it remains on during start up. It will display fine on an external monitor. If an external monitor is not connected, and you...
This sounds like a problem with the back light. The back light is generally a small cool fluorescent light. The problem could be with either the fluorescent light or the inverter board that supplies the voltage to run the lamp. If you are able to disassemble it yourself you can usually buy an inverter and lamp online. This requires a good amount of dis-assembly and expertise but costs less. At a higher price but less expertise is a complete lcd display including frame and covers. This basically just requires removal of the top cover of the laptop to access the screws that hold the display on and access to the cables.
Best of luck, Jim
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
My screen is black on my toshiba satellite m35x-s149 laptop. What do i need to repair this? I currently use a desktop monitor to see but would like to fix and use the laptop as it should be use. Any...
If you are getting display in an external monitor, it means Laptop is working fine except LCD. Better to replace the LCD. It will not coat you much. Contact Service center or Computer accessories dealer, for used LCD, they used to have from old PC.
Aug 20, 2010 | Toshiba Satellite M35X-S149 Notebook
I have green and red running top to bottom on screen
Red and Green Lines on the screen could be graphic card or the screen itself. Try and external monitor and see if you see line there. Yes graphic card No Screen
Nov 26, 2009 | Toshiba Satellite M35X-S111 Notebook
Monotor not working
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Here is the disassembly guide:
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
Hope this helps.
Oct 24, 2009 | Toshiba Satellite M35X-S161 Notebook
Black Screen ALL MOST, some time it is ok, some time not.!!!!!!!
can you try to Attach an external monitor and check if it has the same problem on the external monitor?
Sep 12, 2009 | Toshiba Satellite M35X-S161 Notebook
My toshiba satellite m35x-s311
I have not had one of these to look at, but if it has a vga port, you could try connecting it to an external monitor, in case the invertor, or the backlight in the screen has failed. I fit gives video, on an external, that is the place to start.
Sep 01, 2008 | Toshiba Satellite M35X-S311 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Satellite m35x-s161 non conforming pixels
well, red dot could be a number of things... if they are on the screen at all time they could be stuck or dead pixels which is a probelm in the LCD screen itself. Try these instructions:
http://www.instructables.com/id/Fix-a-stuck-pixel-on-an-LCD-monitor/
Make sure your video driver is updated. If you have the 855GME display adpapter you can find the most recent driver update here: http://cdgenp01.csd.toshiba.com/content/support/downloads/sm35xinvidx.exe
Feb 23, 2008 | Toshiba Satellite M35X-S111 Notebook
Computers & Internet Logo
356 people viewed this question
David Payne
David Payne
