Question about Kenmore 62602 Electric Dryer
Kenmore TopLoad Drying Machine
Model 110-62622100 Serial ML1915424 Type: DWJR-ELE-2406028-FM54 Machine purchased in August 2001. Dryer makes load sqealing noise during operation. I'm thinking bearings or roller problem, or maybe something needs to be lubed. Replacement seems odd since machine is so new.......Please advise. Thanks Tom Yankees1@us.ibm.com
I return home tomorrow and will attack the problem over the weekend. Response time and detail are outstanding. Will comment on final results. I am very impressed with this site!
Posted on Jul 10, 2007
  • 432 Answers
It could be a part in the bulkhead unit. Shaft, Tri Ring, and support roller all fit together. You can put grease on the rollers and shaft support if they are in good shape. You can download the 3D-diagram, and parts list from HTTP://WWW3.SEARS.COM All you need is the model #110-62622100. If you do need parts, you can order them from the website and it comes with an exploded diagram on how to repair it. GO YANKEES !!
  • Raymond Scott
    Raymond Scott Jul 10, 2007
    Following up to see if the solution worked.
I have a Whirlpool DWJR-ELE-2406028-FM54 and when I open the door (while machine is running), the drum keeps turning. How do i remedy this?
sounds like the door switch is broken,good thing it broke in the running position or the dryer wouldn't start.that isn't a good model number either,open the door look around the opening where you put the clothes in and you should see a tag with the model number,you'll need that to order the door switch.the dwjr comes up but not the rest if this is a ge dryer.
Feb 05, 2018 | Whirlpool Dryers
What is the capacity of a Kenmore dryer model 110 62622100
The dryer should hold what the washer will hold especially if there a matched set this one looks like a super cap. hope this helps
Feb 18, 2015 | Kenmore Dryers
Kenmore electric dryer DWJR-ELE-2406028-FM54 Model 110.64632300. when we close the door the start button doesnt work until we close it 5 or 6 times. Help.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 64722 Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
No heat with drying
LOOK AT THE DIAPHRAM. AppliancePartspros.com and looks like the easiest way for this one is from the bottom of the dryer.
Oct 11, 2009 | Dryers
My dryer won't turn on
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
Sep 26, 2009 | Kenmore Dryers
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Jul 06, 2009 | Dryers
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Kenmore 62602 Electric Dryer Logo
207 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
