Fuse blowing on tappan air handler
Our tappan air handler using a 5 amp fuse that keeps blowing causing the thermostat to shut off. THe handler stills blows air but the heating coils cannot kick on without the thermostat. The thermostat is tied in with the air conditioning on the breaker box and the air handler is on a seperate breaker. We have replace the 5 amp fuse several times and it has blown each time. We have shyed away from looking at the air conditioner unit as a problem but we aren't sure what to look for. Do you have any suggestions before we seek professional help?
  • micah_hudson Jan 24, 2009
    That answer is very helpful and sort of confirmed what we had thought. We keep going back to the ac to look at the wires going into it because they look worn a little. We'll take a better look. THank you very much for your help.
    President:
  • 267 Answers
Most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Posted on Jan 24, 2009
    President:
  • 1,214 Answers
There is something shorted in the air handler. It could be a heater element, assuming they are in the air handler (and they usually are.).
  • Mark Egan Jan 24, 2009
    If the smaller wires at the outside unit use only 2 conductors (it could be 2 wires inside of a sheath, and both are used, or 4 wires inside the sheath, and 2 are used) then the problem is inside the house as the blower will not run without 24 volts to make the heat sequencer and fan relay energize.
    Turn the power off to the inside unit, and remove the panels covering the electrical components. Note whether there are any burned wire connections, a common problem with electric heat furnaces. Those need to be repaired, and there is a chance that one or more may be contacting ground. What's weird is the fan continuing to run without power from the 24 volt transformer. It's going to take some investigation to determine what the failure is.
Frigidaire furnace FG6RA 096C-16B comes on ignites starts to blow then 3 amp fuse blows replace it fuse blows as soon as power is on. Help
The problem is in the thermostat wiring, likely it is grounding somewhere between the thermostat and the air handler/furnace unit.
Dec 31, 2017 | Frigidaire Heating & Cooling
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
What cause 3 amp fuse to keep blowing when power in turn on goodman 16 sier air handler
Hello...
Apparently, there is an overload or shorted wires. Elequipo Disconnect electricity and check the cables are in good condition.
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Air handler keeps blowing out transformer
Does it call for a 24v transformer? How many amps does it need. If you have the wrong amps. that can cause issues.
Jan 06, 2014 | Heating & Cooling
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
Air conditioning wont turn of, error code at furnace appears to be 24 - secondary fuse open?
There is a 3 or 5 amp fuse on the control board inside the air handler.
Disconnect power to the air handler,locate the fuse and replace it with a good fuse.
The fuse is the same type used in automobiles.
You can purchase them at a auto parts store.
After replacing and turning on the power there will be a 5 minute delay before the board and thermostat energize.
After 5 minutes set the thermostat for you heat or ac function.
If the new fuse blows a complete diagnostic must be done to the system.
Apr 24, 2011 | Carrier Heating & Cooling
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
1,178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
