Question about LG WM2688H Front Load Washer
My washer won't stay level
Why won't my washer stay level
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Washer won't stay running error code DS
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
Oct 16, 2012 | Washing Machines
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
Coolant light stays on on my bmw 325i
CHECK WHETHER YOU DO NOT LOOSE COOLANT AND THE LEVEL ON THE EXPANSION TANK DROPS AND THE LEVEL SENSOR ACTIVATED. ON THE OTHER HAND IT IS ALSO THE SENSOR OF COOLANT LEVEL WON'T WORK.
Aug 29, 2012 | Cars & Trucks
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Ge Washer won't start, lights come on but won't stay on, what do I do?
Go online and search for brand and model number service manual. There are probably multiple things it could be, but the troubleshooting section should point you in the rite way.
May 30, 2012 | GE Washing Machines
Fisher and paykel won't let water in but just sensing water level non-stop
Any switch the same size will work there fine,
It must have the three pins,com, nc, no on the switch.
May 08, 2012 | Fisher and Paykel Fisher & Paykel Washer
Dryer door won't stay open while removing clothes
Likely the feet to the dryer are not level. Grab a large level and check to ensure the top front is level across.
If your door opens to the right, raise the front left foot by screwing it counterclockwise. Check level, and repeat.
Mirror the operation for a door that swings to the left.
Jan 25, 2012 | General Electric WCVH6400J Front Load...
Battery won't stay charged
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jan 16, 2012 | Kodak EasyShare Z740 Digital Camera
LG WM2688H Front Load Washer Logo
57 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
