Question about Canon PowerShot SX100 IS Digital Camera
EOS Utility program cant download pictures.
Previously the Eos Utility program provided with the camera worked well (on XP sp2) and downloaded all pictures neatly into folders for the date the pictures were taken.
Now however, for some unknown reason, this utility doesnt work. The camera is recognised and is listed in device manager as an "Image Capture Device" as Canon Powershot S3 IS.
If I use the windows native tooling I can pull images off the camera (same with Adobe Photoalbum) - but it doesnt sort them neatly by the date they were taken so its a bit anoying.
Any ideas what might have changed? the canon EOS utility program used to work for me but now does not automatically appear when I connect my Canon PowerShot SX100 camera. Also the camera "freezes" on the last image taken and does not respond when I press the menu button or any other button.....
  • Canon Master
  • 4,738 Answers
It's very hard to troubleshoot software problems online, and it likely is a software issue. You may fix it, but it will pop up again some day. Camera/cable interface problems are notorious. But why put up with the headache of these software problems? Please see the following post, as it outlines a much easier, faster, and less error prone alternative way to download your photos:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Posted on Jan 25, 2009
2 Suggested Answers
  • 45 Answers
SOURCE: EOS Utility program cant download pictures.
1'st thing. You don't have an EOS camera so you won't be able to use EOS utility.
Posted on May 30, 2008
CANON EOS Rebel XSI is not being seen by EOS Utility. I can't update firmware, I can't download pictures, nothing. It doesn't see that it is hooked up. I have tried updating the EOS Utility...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto, Windows Photo Gallery, or ZoomBrowser.
Aug 14, 2011 | Canon EOS Rebel XSi Digital Camera
I have bought a canon EOS 300d camera with out cd. bt when i plug my camera to my computer nothing happens .i tried to do download dpp bt all i fine is dpp updater e.t.c . i have windows xp in installed ....
The updater does not need to have a previous version installed, it will install the stand alone program. However DPP is not the program you need to connect to your camera, what you need is EOS Utility. That is also availible on the Canon website.
May 08, 2011 | Canon Digital Rebel / EOS-300D Digital...
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
EOS Utility
Try not to launch the program from your computer just plug the camera to the computer and turn it on then the program will self launch and maybe all the functions will be avaliable.I hope it'll work
Jun 28, 2009 | Canon EOS Rebel XSi Digital Camera
Switched to MAC - have EOS40D and SX100 - will not download SX100
Yes, you need to install the SX100 driver software as well. I wouldn't overwrite older versions of the Canon software, though, so do a selective install if you can.
Feb 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Will not let me down load
if you are hooking your camera directly up to your pc it will look for the software program to pull pictures off with... if it is not on the pc then hooking camera directly to pc will not work.
it should have come in your box with camera and i think mine said install first before hooking camera up to pc.
but the program is called EOS Utility
Dec 27, 2008 | Canon EOS Digital Rebel XS / 1000D IS...
Nov 16, 2007 | Canon PowerShot S3 IS Digital Camera
Cannot download my pictures
hey found solution,
in Menu > Go to the last setting menu > Communication > and set it to PC Connection
hope this helps!
Nov 11, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Importing pictures using EOS utility
I had the same problem, I think you were missing a driver. if you got to canon usa's page for drivers and downloads you should be able to find it :http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=11154
Sep 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
410 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
