Question about Pool & Spa
Sta-rite pump went dry now does not run
Water supply went dry . power is on , pump wont turn on . don"t see a reset button
    Sergeant:
  • 248 Answers
These really don't like running dry. Disconnect the power and see if you can turn over by hand by turning the cooling fan. If you cannot then something mechanical has failed this could be something on the front end and/or the motor windings. These motors usually have a thermal overload so if you can turn over by hand then the motor either has burnt out its windings or the overload has kicked in leave motor unpowered for an hour and see if it restarts . If you cannot turn over the plastic front has broken. You may be lucky to get parts from a salvage yard as these are usually cheaper to buy as whole unit.
Posted on Jan 15, 2013
  • 17 Answers
SOURCE: 2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Posted on Mar 05, 2009
  • 19 Answers
SOURCE: water comes out of the backflush when in filter mode.
bad gasket on diverter valve
Posted on May 01, 2009
  • 59 Answers
SOURCE: Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
Posted on May 25, 2009
john224
  • 1378 Answers
SOURCE: we have a Sta-rite mode P2RA50-120L, when trying
If all you are doing is running your filter system to waste or backwash the fact that the pool is over full has nothing to do with it. It should run fine in either case. Your motor is likely starting to fail and as it overheats, shuts off. You may want to consider taking it to a local electric motor shop for repair or replace the motor. That motor is somewhere around $150 from most places. We sell it as well. If you would like a quote, please contact www.arrowmotor.net
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: Jacuzzi jet pump doesn't produce much bubbles
A broken jet internal would allow water to run back up the air lines and contaminate the air lines on all jets that are on the same manifold allowing no air to incorperate into the jets stream resulting in low pressure
Posted on Oct 31, 2009
We accidently left our Sta-rite pool pump on when we went out of town for 4 days. It ran dry during this time. Now when we turn the pump on, water shoots out of the top under the handle and makes sounds...
sounds like the heat from the pump melted the seals in your multiport replace multiport and pump you should be ok you will need to replace some of the pvc pipes they expand when heated you wont be able to put fittings on them
Sep 07, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Just installed a new pool pump. runs quiet, but does not seem to "pump"
Check the gate valves before and after the pump to make sure they are open all the way and to make sure the body of water is full enough so the pump does not cavitate the pump.
Rod
US Parts Center
888-521-6183
Feb 18, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
My Sta-Rite poll heater doesn't work. The heater comes on when every time I restore power to the unit, the membrain buttons only work to change the temp. ont to shut off the unit, I use the service...
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
Sep 12, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
No power to unit how do you reset breaker to unit.
Turn the breaker all the way OFF, then Back ON. Also, you may have a GFCI receptacle that tripped, in which case just push in the reset button.
Jan 17, 2011 | Sta Rite Sta-Rite IntelliPro 4 X 160 Pump
1 HP StaRite Pump 15" inout Center Discharge 240V wHair Lint Pot: Impellers on pump wont turn. Motor not running...
what happens is the pump gets staved for water and this damages the shaft seal, water slowly over time leaks into the motor and pollutes the grease int the bearing and causes it to fail. it's fairly easy fix, just have the motor rebuilt by your local pool pump motor repair guy for about 75.00 and your back up and running. beats paying 200.00 or more for a new motor.
the sta rite is the top of the line pump, i have had them in my shop over 40 years old ! ask your motor repair guy how to get the most life out of your pump. knowledge is king .. remember to prime the pump after any pump repair !! .. jay longwood florida
May 17, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Aug 26, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pool & Spa Logo
107 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
