Question about GE Profile WPRE6100G Top Load Washer
Loud spin bearing
Loud noisewhen spinning, my ge profile washer has been making the spin bearing for awhile. Most likely caused from maching being groosely overloaded. need a new bearing and some instruction in doing this repair
  • GE Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 15, 2013
gittos73
  • 244 Answers
SOURCE: very loud washer during spin cycle
it will be your bearings not the belt or pulle you can check this out by having it empty open the door place the palm of your hand on the outside were the top of the door closers to place your fingers ti the inside of the top of inner drum and pull your fingers towards your palm if there is the slightist movement than the bearings need replacing
Posted on Aug 22, 2007
SOURCE: GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Posted on Nov 17, 2007
Krazytech
  • 725 Answers
SOURCE: GE PROFILE WASHER M# WPGT9350COPL
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Posted on Sep 13, 2008
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
  • 103 Answers
SOURCE: front loader making loud noise with spin cycle
i have the same problem as urs. i open the whole drum myself and replaced the rear bearing. but the actual problem is the bearing housing is loose in plastic drum. so only drum needs to be replaced.
Posted on Oct 23, 2009
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
My washer tends to have difficulty spinning if the load is too heavy and it is really loud when it does decide it will work. It works well with smaller loads but when i try to wash more than just a few...
Your load drum bearings appear to be in the process of seizing, thus putting excessive load on the drive motor and this causes it to trip its self out
Jun 24, 2010 | GE Profile Prodigy WPSE4200A
My GE washer makes loud noise only on slow spin. I tried leveling it but it still makes noise.
likely the main bearing is failed.
Big Job.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE Profile WPRE6100G Top Load Washer
Very loud during the spin cycle
the top bearing has gone bad you are looking at replacing the transmition and tub seal about 200 dollars in parts the labor is a little tough also you got to completly disasemble the machine to do this may be best to get a new machine
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
GE Profile Model WMSR3110W2WW washer
Your bearings may be going.. does it make a racket as it spins too.. bearings come as sealed units, when they break down oil leaks, hence the stains.
It will only get worse so have it sorted to save your washing.
sue
Aug 18, 2008 | GE Profile WPSR3120WWW
Ge profile WNSB8060BWW VERYYYYYY LOUD
Rear ball bearing broken change half drum or buy new washer ????????????
the super tech
Sep 04, 2017 | GE WNSB8060BWW Top Load Washer
Very loud washer during spin cycle
Dec 11, 2006 | GE Profile Prodigy WPSE4200A
GE Profile WPRE6100G Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
