Question about Acer Aspire Computers & Internet
EL1358G-51w will not boot because windows couldn't load..I have a 52w that lets you return to factory in the boot mode but the 51w does not give that option..HELP
  • William Josey Jan 15, 2013
    THIS FIX WAS EASY TO FOLLOW AND WAS RIGHT ON THE MONEY...TK'S 4 THE STEP BY STEP ANSWER !
    Scholar:
  • 58 Answers
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source: http://windows-8-password-recovery.com/computer-wont-boot.html
Posted on Jan 18, 2013
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
  • 85 Answers
SOURCE: windows wont load
u have to reinstall xp
Posted on Jun 01, 2008
SOURCE: Can't System Restrore Dell Inspiron 531.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
parrotheadpc
  • 2600 Answers
SOURCE: on boot up 1st black screen with boot up options
follow this fix and see if it corrects the problem.....
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 13, 2009
  • 11800 Answers
SOURCE: I can't get the laptop
Windows is totally corrupted. Sorry it's to late to fix it, your only option left is to reinstall.
Posted on Sep 25, 2010
Testimonial: "I found this information to be helpful."
How can I restore emachines EL1358G-51W?
If you can boot into Windows 8
  1. Power on your computer.
  2. Press the Windows and C key to begin a search.
  3. Type recovery and click eMachines Recovery Management.
  4. Click on Restore Factory Settings, at the Restore tab from the left menu.
  5. Click Next.
  6. Click Fully clean the drive option.
  7. Click Reset.
More items...
eMachines Recovery Disk - Guide for Windows XP, Vista, 7, 8
How can restore emachines EL1358G 51W Google Search
Jun 27, 2017 | eMachines Computers & Internet
Open case how to el1358g
9xejsknreuu9+p8eghor1yaijqaaaabjru5erkjggg==The Two Thumb Screws above and below.
Feb 25, 2014 | eMachines EL1358G-51W Desktop Computer...
Can video card be upgraded in emachine el1358g-51w
yes you can upgrade the graphics card, you have integrated graphics but you can purchase a PCI-E graphics card and bypass the on board graphics but keep in mind you'll have to buy a "low profile" graphics card as there's not much room in your case and a full size card will not fit.
Sep 26, 2013 | eMachines Computers & Internet
Keeps crashing before it gets completely on
Yes, I use them for a year, and then they sell them.
Is there a problem?
OH, C'MON I'M JUST KIDDING!
1) Is the computer dirty inside?
The two major issues with desktop computer failure, is the computer is dirty inside; and Power Supply failure.
Post back in a Comment. We'll start here.
Be prepared for a 'Windy' tech. You may do so much reading, you'll feel like you are back in school.
(I explain in detail, as if you know absolutely nothing about your computer. Just the way I ride )
Regards,
joecoolvette
Mar 06, 2013 | eMachines Acer Emachine EL1358G-51w 2.8GHz...
El1358g-51w loaded drivers so far and then stopped error message read i had to restart and it would load and did not
You will have to reboot into safe mode to remove those drivers from the device manager and then reboot and allow windows to find the drivers it wants and not the drivers you think are the right ones because sometimes a flaky driver will stop windows cold and lock it into a loop forever.
If you do not know how to boot into safe mode, when you turn on your computer, the moment you see anything on your monitor start rapidly pressing the F8 key until you get a boot screen that has a choice of booting into safe mode, then follow the directions and when you finally get into windows go to the device manager, (in most windows will either be accessible from the control panel or from the control panel then clicking on system>then hardware tab>then device manager button.
Nov 30, 2012 | E-Machines eMachines Desktop PC
Replace power supply
Be sure to look on back of tower to see what power you need. The power plug needs to be 115v or 125v on most. Be sure your cord is the same voltage.
Nov 15, 2012 | eMachines Acer Emachine EL1358G-51w 2.8GHz...
Need user manual for eMachines Black EL1358G-51w Desktop PC with AMD Athlon II X2 Dual-Core 220 Processor, 1TB Hard Drive and Windows 7 Home Premium (
Here you go [http://www.dl-provider.com/search/emachines%20el1358g%2051w%20manual%20.pdf.html?aff.id=1376]
Jan 10, 2012 | Computers & Internet
Can't return from standby mode. the vga, sound,
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
May 31, 2011 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
