SOURCE: Leaking from the front ?
Hello Kathy J...
It sounds as if you want reassurance that you should replace your dishwasher.. The costs associated with replacing the racks themselves and the gasket on the door ( depending on who does it) might justify the purchase of a replacement model.. Plus newer models are more energy efficient that the older ones.. 7 years of use is a fairly long time so you've gotten your money out of it... I always use this litmus test to validate the purchase.. if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense.. Very subjective indeed.. hope you make the right choice.. :-)
SOURCE: Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
SOURCE: dishwasher leaking out the bottom of the front door
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
SOURCE: soap and water leaking at bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ghdjkdghas
