Question about Maytag Refrigerators
Maytag fridge MF12269VEM7. icemaker won't work. water dispenser works. freezer temp at 0, fridge temp at 38. no apparant ice build up . churner works but no ice
dididsaythat
  • 291 Answers
SOURCE: Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Posted on Sep 03, 2007
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
Posted on Nov 11, 2008
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
Maytag MSD2651HEW only sends cubed ice - won't send crushed. Also problem with ice maker spilling water - are these problems related?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Oct 02, 2011 | Maytag MSD2651 HE Side by Side...
I have a GSS221FRFWW with and ice and water dispenser problem. The light in the dispenser has gradually gotten dimmer, and the water won't dispense unless you remove the light bulb. The ice maker...
NOTE: This
Leo Ponder
imufo2
Sep 30, 2011 | Refrigerators
My electrolux fridge has a few problems. First, my ice drawer won't come out, Second my ice maker doesn't work and third, the water coming out of the dispenser is not cold.
NOTE: This
Leo Ponder
imufo2
Sep 25, 2011 | Refrigerators
Maytag VFI2569VEM icemaker won't make ice
NOTE: This
Leo Ponder
imufo2
Sep 20, 2011 | Maytag Refrigerators
The ice/water dispenser on my french door maytag fridge does not work. when a cup is pressed on the flap, there is no sound, nothing. it had been working sporadically but we had to push hard and...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Sep 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Our ice maker seems to be working, OK, but all of sudden, it won't dispense water in to the trays. The arm goes up and down and I can hear it trying to work, but again, no water is now dispensing in...
NOTE: This
I'm
Leo Ponder
imufo2
Sep 05, 2011 | Refrigerators
I HAVE A MODEL MFI2568AES MAYTAG THE ICE MAKER DOES NOT MAKE ICE. THE WATER DISPENSER DOES WORK.
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 10, 2011 | Maytag MSD2651 HE Side by Side...
Won't dispense ice
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Maytag psd245ogr refrigerator, no water, no ice. Started with hollow cubes and over time smaller and less cubes. Finally, no ice in freezer and no water or ice at the door dispenser.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Maytag MSD2454G Side by Side Refrigerator
Aug 27, 2007 | Refrigerators
Refrigerators Logo
420 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
