Question about Maytag Portable Air Conditioner M6P09S2A
Red light came on and air conditioner will not turn back on
Air conditioner shut down on it's own. "!" in a triangle icon and red light came on, and unit beeps ... but the a/c unit will not turn back on. What is the "!' icon, and is there a fix/reset for the a/c unit?
Any help is MOST appreciated!! :)
Thanks MUCH!
  • Anonymous Apr 20, 2009
    Same
  • jmcnabb440 May 07, 2009
    Unit had not been used for some time and when I turned it on it came on for a few minutes then shut itself down and beeps in a regular pattern. Tried cleaning everything I could , checking the vent hose, even unplugged and let it sit for some time. Still will not work; only beeps with the red light / exclamation point.
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Posted on Jun 03, 2009
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
My LG split air conditioner beeps and turn off by itself. The it beeps flash 2 times the on and off light and shuts down by itself. How to fix it ?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Coral Springs
Nov 30, 2015 | LG Heating & Cooling
I have the Commercial Cool Model# CPR07XC9-LW 7000 BTU and it has been shutting down in the middle of the night. It beeps and a red light flashes on it. What does this mean?
It means that condensed water has accumulated in the unit. In the rear, on the bottom right, there is a water outlet drain. Tilt the unit slightly to drain the water in there. Be sure to unplug the unit first.
Jul 13, 2011 | Haier Heating & Cooling
The Model # is HPRD12XC5. A red light went on next to the AC fan
The water pan in the bottom was probably full. Did you try to drain it? First uplug the machine from the outlet. There should be a little knob to unscrew in the lower back of the machine. Once you remove it, pull out the little black stopper and have a very shallow pan ready to collect any water. Once everything is drained, replace the stopper and the knob, plug it back into the outlet, and press the reset button. Turn the unit on and wait a couple of minutes for the compressor to start.
Jul 31, 2010 | Haier HPAC90ER Air Conditioner
Samsung Air Conditioner will not turn back on after power Outage
disconnect the units from their power source and wait about an hour. Reconnect to power source and see if this has reset the units.
Hope this helped you good luck on the repairs
Dave
Nov 11, 2009 | Samsung AW1403B Air Conditioner
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Heating & Cooling Logo
2,852 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
