Question about O2 Xda II Smartphone
I have lost my pan.how to buy. - O2 Xda II Smartphone
  • 115 Answers
The easiest and cheapest way to replace the stylus is in eBay. Do a search on your units brand name and model and the word 'stylus'.
I prefer this way, as one it is cheaper, two, I can buy packs of three or more, This way, when you lose the next one(and you will), you can grab one of the extras out of your desk drawer(less down time).
And be careful about what you are using now for a stylus. Nothing with a point on it (yes, I did that too)
Posted on Jan 24, 2009
I have a Le Pan tablet and i lost my original charger, I bought one at Walmart and it won't charge my tablet
if it is not the same brand chrger that u had frst then it wont work, if u buy the same brand then it will work, sorry about that
Nov 27, 2017 | Tablets & eReaders
TJ 4.0l. oil pan bolt pattern or layout for for the bolts
engine pan or trans pan,(guess at engine)
what's up doc.?
what is the job.
lost the gasket?
lost the bolts.?
not sure what going on here.
buy a new gasket from Felpro and bingo? there be a pattern
May 21, 2016 | 1998 Jeep Wrangler
I had lost the screws to attach the stand i have a 42lg30 tv AND IM TRYNA FIND THE SIZE OF THE SCREWS I NEED SO I CAN GO BUY REPLACEMENT ONES
Those are metric screws. I forgot the exact size, but I think it is Pan-head M4 fine thread. You could buy sets of M3 thru M5, and one of them should fit. Return the wrong ones.
Aug 06, 2011 | Audio Players & Recorders
Oil pan plug does'nt have original one, cant i just buy a new one instead of a whole new oil pan
Basically oil pan plug is nothing but a bolt with crush washer. Buy the bolt of the same no. as the old plug one and new crush washer with it. Just make sure you buy a good quality bolt.
May 03, 2011 | 1997 Toyota Camry
Lost manual need to know if the trilium TR 500 breadman is a 1 lb or 1 1/2 lb machine and directions. lost the manual
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
Dec 17, 2010 | Breadman TR500 Bread Maker
It not geting data. i was formate it last time after then it shows there is 0 cpasity in your pan drive. i m having 4gb pen drive. my contect no is 09634039903. plz help me.
Hi.
Im sorry to hear that you lost all your data in pendrive.
Use Recover My Files to recover your usb contents "FILES". Dont use that usb again. Buy a new one.
Nov 11, 2010 | Computers & Internet
Cant get oil plug loose
FIRST: oil the plug (I know it sounds redundant)
1. breaker bar instead of ratchet wrench (buy one if you dont have one)
2. extension bar on breaker bar handle
If Getting desperate:
1. buy a new oil pan plug
2. use a damaged/rounded extraction socket on a breaker bar.
3. use an extension handle on the breaker bar handle
Be prepared to buy (and install)a new oil pan if the threads on the oil pan are ruined.
Installing a new oil pan is "easy" for experienced mechanics, but
replacing one can be involved for 1st-timers - and you'll usually want to buy (and install) a new oil pan gasket with the new oil pan.
That's everything from breaker bar (your minimum for stuck bolts) to replacing plug and pan (the worst-case scenario).
Sep 21, 2010 | 2006 Chevrolet Monte Carlo
The car is leaking oil and the mechanic said it was because there is a whole in the oil pan and it will cost 1800 to fix. can i buy another oil pan and put it on myself?
OIL PAN
REMOVAL
Drain engine oil.
Remove front engine mount bracket.
Remove power-train bending strut.
Remove structural collar from oil pan to trans-axle Structural Collar - Removal and Installation
Remove trans-axle lower dust cover.
If equipped with air conditioning, remove oil filter and adapter.
Remove oil pan.
Clean oil pan and all gasket surfaces.
INSTALLATION
Apply Mopar® Silicone Rubber Adhesive Sealant or equivalent at the oil pump to engine block parting line Oil Pan Sealing
Install a new oil pan gasket to pan.
Install pan and tighten screws to 12 N·m (105 in. lbs.)
Install oil filter and adapter.
Install trans-axle lower dust cover.
Install power-train bending strut.
Install front engine mount and bracket
CAUTION: The torque procedure for the structural collar must be followed, as damage to oil pan or collar could occur.
Install the structural collar Structural Collar - Removal and Installation using the following 3 step torque sequence:
Step 1: Install the collar to oil pan bolts and tighten to 3 N·m (30 in. lbs.)
Step 2: Install collar to trans-axle bolts and tighten to 108 N·m (80 ft. lbs.)
Step 3: Final torque the collar to oil pan bolts to 54 N·m (40 ft. lbs.)
Fill engine crankcase with proper oil to correct level.
Auto Zone carries the Oil pan you need for around $75.00 and they will have the step by step instructions for you to replace the oil pan. will take just over 2 hours for the average person. Good luck and keep me posted.
Nov 30, 2009 | 2002 Dodge Neon
Rectangular box behiond oil pan lost bolt and
My guess is that it is the transmission pan. Check your transmission fluid to see if you have any.
Oct 19, 2009 | 1997 Lincoln Town Car
Leak on left fron area
the defrost drain does not regularly need to be emptied, it will evaporate on its own, if you are indeed leaking from the defrost pan perhaps you have a hole in the defrost pan, or a partial blockage of the defrost pan so the water does not spread throughout the whole pan call a service guy or just take off the back panel and look at the whole pan with a flashlight.
Aug 27, 2009 | Estate TS25AFXK Side by Side Refrigerator
O2 Xda II Smartphone Logo
22 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
