Question about Wharfedale Moviestar 70+ System
Wiring diagram warfdale 70+ speaker system
Units been disconnected and I dont know how they go back to gether
Trying to match my aftermarket radio with factory speaker wires.. BROWN YELLOW GREEN VIOLET / WHITE STRIPE LT BLUE LT BLUE / BLACK STRIPE WHITE /RED STRIPE WHITE / RED STRIPE
Greg, Check the attached links,instruction and guides stereo and speaker wiring, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WIRE COLOR CODES FOR CAR INSTALLATION
Car Stereo Wiring Diagrams and Car Radio Wiring Diagrams
https://www.installdr.com/quickwiring.asp
Car Stereo Wiring Diagrams Director
Apr 03, 2016 | Cars & Trucks
I need a wiring diagram for Technics Stereo Systems
Speaker wiring, input wiring, adapter wiring, HDMI, RGB, Video or internal wiring? Do you have a model as many units wire up in different ways...
Feb 21, 2012 | Audio Players & Recorders
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
Same problem need answer diagram
Try this:http://astrosa.com/n03/speed-control.pdf
Sep 07, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Need a wiring diagram for warfdale whcd930mp3 car audio
see if the wire colours look to be the same
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 30, 2009 | Car Audio & Video
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
2000 mustang convertable amp problems
Are you sure the amplifiers are trashed? Have you checked the fuses? A reputable car audio shop could help for a fee of course, but it may be worth the price. It's odd that (all) the amps would malfuntion simultaniously unless someone unqualified messed with the wiring or the radio has a defective trigger wire (turns the amps on). You'll be sadly disapointed with any new radio without the factory amps, especially with the convertable ... I strongly suggest getting the amps (the factory system) working again.
Apr 17, 2009 | Metra Turbowire 70-5605
Kenmoore 70 series dryer wont start
Are you 100% certain the dryer has 240 VAC? Just because a light may light does not guarantee both legs of 240 VAC are hot.
If you measured motor continuity, then you must be able to read a wiring diagram/schematic. Most Kenmore units have a wiring diagram/schematic glued to the back of the rear service panel, or folded and stored in the control head.
I am unable to find a wiring diagram on the internet, but, you have a door switch, and the timer/control.
Use the wiring diagram to trace the signal path's to determine where the failure is.
Let me know if you have any questions and I will do my best to help.
Jan 21, 2009 | Dryers
Kenmore 70 series
The following link explains how to replace a pump on a Kenmore top loader:
http://www.fixya.com/support/r397092-replacing_water_pump
The pump is only held in place by two retaining clips. Once the clips are removed, the pump (with hoses still attached) pulls directly off the motor shaft. NOTE: If the pump is leaking, it is NOT repairable and requires replacement. These pumps are sealed units. Replacements can be ordered on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offere competitive pricing so shop all three for the best price. If you require addtional assistance, please let me know. I hope this helps you.
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Open Questions:
See all Wharfedale Moviestar 70+ System Questions
Wharfedale Moviestar 70+ System Logo
71 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
