Question about AEG B1180-4 Electric Single Oven
AEGB1180-4 overheating/cutting out
I think 'colburn' has answered this one wrt to cooling fan controller. My problem is similar/identical as described previously. When hot the oven control cuts out until the oven cools then works normally. Question: how easy is the control unit to replace? and where can I obtain the part? Thanks in advance
  • Scott Muller Jul 12, 2007
    Pilky,
    thanks for the suggestion. i replaced the thermal overload cutout, and the oven works. The old one was charred.
    If it goes again I will bypass as you suggest.
    Thanks
    Problem Solver:
  • 18 Answers
It is not the control unit. Remove oven from housing, switch power off and remove either the top panel or the back of the oven You will see two wires going to a thermal overload cut out, looks likse a round thermostat. Join the 2 wires togther bypassing the toc, it will now work okay
Posted on Jul 12, 2007
Bosch oven cooling fan behind top oven not switching off after using main fan oven
stat problem stat that controls fan function is not openning telling control oven is still hot How Does An Electric Range Oven Work Appliance Repair
Jan 29, 2017 | Bosch Ovens
Smeg duco8css cooler fan not working
IT IS POSSIBLY THE FAN OR ITS RELAY IS BAD BUT I WOULDN'T JUST GO OUT AND BY EITHER UNTIL THEY WERE CHECKED WITH METER
Apr 21, 2014 | Smeg DO8C Electric Double Oven
After baking at 425 degrees, ew30mc65js2 will not shut off - fan continues to run and some heat, although lower, continues after 1.5 hours
Hi - if you still have your user manual I think you will find that oven have a time delay designed into the electronics for cool down purposes after the cycles completed. If it does shutdown after say 1.5hrs, it may seem a bit long but its actually doing what its designed to do, it should not be heating but circulating the hot air thru the oven.
We use to have a similar problem with our F & P BI600 wall oven - what we've done is have the door slightly ajar to quicken the cool down process until one day the fan ran continously - then I had it disconnected.
I hope this may help with your situation, if its running continously then its best to disconnect the cool down fan, the bake fan is normally on a separate circuit and not affected.
Jul 13, 2011 | Electrolux Ovens
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
There is a loud buzzing from our Tecnik 1285 range cooker. The buzzing starts about 5 minutes after turning either of the ovens on, and only stops 10 minutes after turning it off. The front of the oven /...
its the cooling fan to keep the control and metal and top of cooker cool. mine is also extremely loud. I think it basically turns unecessarily quickly and could be slowed with a resistor in line
Jan 20, 2011 | Tecnik Ovens
Hi I need the operating instructions for an aeg cooker pnc 944 185 047. ive set the time but I cant work out the timeing settings it keeps switching off after about 20 mins and turns its self back on...
hi you can get instructions fron serviceforce.co.uk . follow the instruction link and enter pnc no. however i think your problem is a controling stat for the cooling fan if the fan does not switch on the oven overheats the cabinet and switches off like you describe. its located in the wiring loom behind the control panel. the part is 899661927356-9 costs circa £26. hope this helps
Nov 21, 2010 | Ovens
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
AEG B1180-4 Electric Single Oven Logo
474 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
