Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No air movement at evaportive
The fan and compressors at the rear of refrigerator comes on. The frezor side blows some air and is cooling fine. The 2 fans at the evaportive will not come on. The lower fan at the crisper drawer area comes on.I replaced the evaporative fan kit and they still will not come on .
What could be the problem
Thanks,
luke
  • 1 more comment
  • italex99 Jan 24, 2009
    would the mother board be the same as the inter face customer asm.
    Luke
    I will get this replaced and get back to you with results.
    luke
  • italex99 Jan 25, 2009
    The mother board was the problem.Thanks for your help.
    President:
  • 267 Answers
Mother board problem . check with ge your might be one of the recalled for this . 1-800-GE-CARES
Posted on Jan 24, 2009
  • BOB  BROWER
    BOB BROWER Jan 24, 2009
    NO . mother board is behind refrig under a metal cover right on the back of the fridge . take a look , remove cover you will see it
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Hot point Manufactured by GE MD# HSS25GFPE WW Not Cooling Fridge or Freezer.
Is compressor (black canister)running? It should be very warm if it is. If not, motherboard is most likely bad.
Oct 20, 2017 | Hotpoint HSS25GFP Side by Side...
The compressor runs and freezer is cold, however the refrigerator side isn't cooling well. Doesn't feel like any air is blowing in the fridge, only the freezer. I tried turning off/resetting the system...
Your model numbers are a waste of time...
Kenmore 5522 / 655224 / 55222 / 55229
Side by Side Refrigerator... PICK One...!!!
"The" fan...??
There should be TWO fans running...
and the FAN that REALLY make the difference in your
described symptoms ... will not run with the DOOR
open (your evaporator fan).
Possible issues:
Fan motor, blades/air blocked by ice, broken blade,
defective door switch or control board...
I always preach... giving a troubled refrigerator
a THREE DAY defrost... but the other day I found
a solid ice block sitting all SNUGGLY in the middle of
an evaporator...
If you are not willing to do that... (3 day defrost)
open it completely and have a REAL GOOD look
around the EVAPORATOR & FAN.
Never use HOT air... soft plastics can be easily ruined.
Take your MODEL NUMBER...
And look on:
Appliancepartspros:
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Happy hunting...
Carnac the Magnificent
Aug 16, 2017 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
REPLACED EVAPORATOR FAN YET I CAN'T FEEL NO
There are two fans in most modern refrigerators; one that circulates the cooled air between the two compartments, another that pulls or blows air over the external coils under the cabinet. You may have bet on the wrong one.
Oct 24, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators is not blowing cool enough air to freeze or cool each side respectively.
I assume the compressor is running since you indicate you have some cool air.
Check to make sure the compressor fan is running. This fan should be near the compressor. Its purpose is to pull room air across the coils and remove the heat from them. If this fan does not operate properly, the refrigerant will not be cycled properly. If the fan is not turning, you will need to replace the fan motor.
Oct 17, 2009 | Refrigerators
No cooling, coils frosting up, defrosted with blow dryer several days ago and cooling fine again, but frost is building up rapidly again. I suspect a defrost heater, please confirm and where to order a...
The evaporator (inside) coil can ice up for the following (typical) reasons. Check the ones that you can and hire a professional refrigeration technician if you can't find the problem yourself.
1. Thermostat isn't shutting off. (Does the compressor run continuously? Can you turn the compressor off while it is running by turning the freezer temp control down (but not off)?
2. Internal fan (evaporator fan) is not blowing air. Possible causes: fan blades hitting something; debris blocking air flow; fan motor bad; no power to fan.
3. Low refrigerant (freon) charge. Need a technician for this one.
You can get thermostat or fan motor at a local appliance parts store. Try googling "appliance parts <yourzipcodey>"
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Access to condenser fan in kenmore bottom freezer
the heater you mention has zero to do with evap fan
does it make ice? if so freezer is fine and problem is air to fridge side blocked
Aug 23, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator cools, but no freezer fan & no condensor fan running
Check the back of you fridge and make sure the coils are clean. If you have access to a small air compressor, blow everything out and make sure the motor are is clean. The build up of dirt on the coils will not let the heat escape during the cooling process.
Mar 04, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer is fine fresh food side wont cool down
Could be a fan problem; some blow cold air, some just have the coil running throught the back inside. Yo will also get very extended life if you plase a very small fan blowing over the compressor if it does not have one.
Dec 28, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
181 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
