Question about DISH Network ViP 922
Vip922 keeps rebooting - DISH Network ViP 922
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 25, 2010 | Vizio L37 Television
Keeps rebooting itself over and over
SIMPLE FIX:
Symptom: My blackberry BB keeps rebooting and restarting; endless loop.
Solution: Remove battery, Re-Insert Battery, replace case backing & PRESS & HOLD on back of casing when reboot gets to just before home screen.
Keep holding until home screen comes up completely and everything loads. (usually 10-15 seconds once home screen appears)
IMPORTANT: WHERE to press & hold back of phone/battery casing when rebooting;
On back of phone casing there are 2 gold strips that hold 2 gold nodes on phone down. THIS IS WHERE you press.
In essence you are firmly holding these nodes down with back casing on, just as phone reboots to home screen.
Works every time for me. Hope it works for you.
Jan 23, 2010 | RIM BlackBerry Bold 9000 Smartphone
I have pcchips m955g motherboard, comp reboots during
If the computer keeps rebooting when you first start it up it is quite possible that the hard drive is broken. It keeps looking for the start up boot sector, but it's broken so it keeps trying again..and again...and well you know.
Hank
Nov 30, 2009 | Computers & Internet
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
XP Keeps Rebooting at Startup
Most likely it is your hard drive. There is a boot sector on the hard drive and when xp starts it looks for that boot sector. If that boot sector is damaged xp can't find it so xp reboots again...and again...and... Try a different hard drive and see what happens.
Hank
Oct 05, 2009 | Microsoft Windows XP Professional
Gv800 16 camera keeps rebooting
It reboots because you probably have cameras that have a lost video. Disable these cameras and it will not reboot
Sep 17, 2009 | Geovision GV-800-16 Video Capture
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
Mozilla firefox keeps asking me to reboot, even when I try to rem
This is due to the registry entries that are installed with Firefox. Any major changes to the system registry requires a reboot. However, a reboot in this case is not immediatelly necessary. You can ignore this error and reboot later if you are working on something, or close out all programs and reboot the computer.
I hope this helps. Please let me know if you have any questions.
Thanks, Raph30
Jan 26, 2009 | Mozilla Firefox
T3882 keeps rebooting
there could be possible problems with ur smps... dat wil make it reboot frequently ,cos of low power supply to the board... anyway, first try to reinstall the os...
Jul 01, 2008 | E-Machines eMachines Desktop PC
DISH Network ViP 922 Logo
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
