Question about Datacard Group Cp40 Plus Card Printer id-card Color
ITS SAYING THAT THE PRINTER HAS NO RIBBON OR IS THE WRONG ONE BUT IT IS IN THERE
My printer is a Sony color printer up-51md and it is saying that the color ribbon is 0 but I have put in a new ribbon and it still won't print, help please!
Follow these steps to see if the problem can be resolved.
1.) Turn the printer off.
2.) Unplug the printer from the power source.
3.) Wait 5 minutes.
4.) Remove the ribbon.
5.) Reinstall the ribbon.
6.) Reconnect the printer to the power supply.
7.) Turn the printer on.
These steps assume that you can replace the ribbon with the printer off, if you cannot, follow the steps in this order: 1,2,3,6,7,4,5
Please let me know.
Dec 17, 2015 | Sony UP 51 MDS Printer
I HAV A DATAMAX I-CLASS PRINTER IT IS SAYING THAT I HAVE A RIBBON FAULT AND THE PRINTER IS THERMAL
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Feb 16, 2015 | Datamax I-4208 Thermal Label Printer
Poor print quality
Several checks:
- Just saying...Ribbon sometimes is placed in the wrong sense and it doesn't print.
- Verify the settings at printer driver. Download a powerful Driver from here: http://www.nicelabel.es/downloads/nicelabel-designer-pro/?uid=10004, and test the darkness option by printing with different measures at each time.
- If that doesn't work, we can check it again, but you should first test this options.
Jul 03, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Screen reading wrong ribbon - had the same ribbon in it since the last printing.
My DTC300 printer has the same problem.
The ribbon supply roller is driven by a small motor connected via an O-ring belt. The printer rolls the ribbon back and forth to locate the start of each color panel on the ribbon during printing and ribbon detection. Without the O-ring, the ribbon only moves toward the take-up spool, eventually going slack so that the color detector only sees one color - hence the "wrong ribbon" message. In my printer, the slack ribbon also gets chewed up in the print head.
You can order a whole belt kit (~ $20 + shipping) or you can locate a generic O-ring belt (1.8mm x 26mm).
Cheers
Sep 27, 2010 | Fargo DTC-300 Thermal Card Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Datacard sp35 is saying it has a k ribbon but really has the color ribbon. It will only print in monochrome
Most likly problems in order of most common,
Bad RFID radio tag in take up spool of printer ribbon,
Bad RFID reader in printer
Printer need firmware upgrade to help in reading weak tags.
Fist would try a new ribbon, if that does not get it will need service. Contact MIdWestIDSolutions.com
Oct 12, 2009 | Datacard SP35 Printer
My zebra printer s4m is saying ALERT CLEARED HEAD OPEN, ALERT RIBBON OUT
Alert Head Open will show everytime u open the Head , when u close back the head it will show Alert CLeared Head Open, then it's normal.
Ribbon Out Show means the printer doesn't detect a ribbon, make sure there's nothing wrong with ribbon installation. if everything fine, then the problem is you Ribbon Sensor. u can try to adjust the sensor with a screwdriver ( - ), make a little bit higher
Jul 11, 2009 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
Ribbon problem
is the ribbon new?, sometimes they have problems, if that one is alright, u need to send it to a repair centre, it must need to repalve the mainboard
Jan 04, 2007 | Olympus Camedia P-10 Thermal Photo Printer
Datacard Group Cp40 Plus Card Printer id-card Color Logo
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
