Question about Desa International GWRN18 Infra-Red Wall Mounted Panel Heater
Desa International GWRN18 Infra-Red Wall Mounted Panel Heater smells of gas
The gas heater is leaking. what to do?
4 Suggested Answers
SOURCE: fumes from Glo-Warm gas heater made by Desa International
If it has not been run for several months it could be dust burning off.
Posted on Nov 20, 2008
  • 10 Answers
SOURCE: I BOUGHT A USED UNVENTED
Check manual, get LP conversion part number than order. If no manual look online under the model number and look up.
Posted on Oct 05, 2010
  • 4736 Answers
SOURCE: I bought a new Desa
Yes, click on the following link and it will take you to Master Distributors. They stock DESA/Vanguard parts. Sorry that you'll have to pay for something that was supposed to come standard with the heater. http://www.vanguardheaters.com/
Be sure you have your Model Number handy when ordering.
Posted on Mar 10, 2011
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
My heater control valve has a small leak it looks like water is dripping from it
Not enough information to fully answer question.
Control valve is usually associated with the gas line and gas control valve.
There should not be water dripping from control valve.
Open following link to help identify source of leak on tank-type water heater
http://waterheatertimer.org/Water-heater-is-leaking.html
If you are uncertain about parts on gas water heater, I suggest calling service technician.
There are several advantages. The technician can service the appliance and ensure there is no dangerous gas leaks or dangerous CO vent leaks.
And if your water heater is rusted and leaking, then service technician can prevent a possible flood.
Some gas is heavier than air and settles to floor, so always check for gas smell near floor level.
The combustion product from a water heater contains odorless CO which is poisonous, and must be vented outdoors so it will kill other things besides you.
The service technician can also see maintenance issues since gas water heaters require yearly maintenance, and some require more frequent attention.
Finally the service technician can give you a few tricks and tips for taking care of your water heater.
If you add a comment with the brand, type and model number of water heater, I can possibly locate a manual for that product which can help both you and me understand your water heater better.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Water Heaters
I have a 40 gallon rheem water heater for a mobil home that is leaking from the top.
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Open following link if you want to install your own gas water heater:
40 gallon electric heater at Lowes costs 207, and is easy do-it-yourself using same basic information shown in link above for installing gas heater, except less work.
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
Trailers require specific type of gas water heater, so be sure to request correct model.
If you maintain the tank: keep chemicals out of same room as gas water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean gas burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Apr 08, 2011 | Water Heaters
When water heater is off a strong gas odor is present. checked by closing or shutting valve control assembly to off positon, where no gas ordor is present.
You may have a leaking gas valve control. Make up a squirt bottle of soapy water (use dishwasher soap and water) and spray the On-Off-Pilot knob for leaks, as well as the pilot button. Look for bubbles forming. Also check all the gas line fittings and connectors hooked up to the water heater for leaks. If you are smelling gas, do not attempt to relight the water heater. Close the shut-off valve on the gas line and see if the gas smell goes away. If it does, you may have to replace your gas valve. Depending on the age and condition of your water heater, it may be more cost effective to replace the control or buy a new water heater. Reliance is a common brand sold at stores like Lowe's. Typically, parts like your gas valve will usually only have a 1 year warranty. Check the manufacturer decal on the tank to see what their actual warranty period is. If you find a leak on the gas line itself, you will have to turn the gas off at the natural gas meter before disassembling the line to fix it. Use a soft setting teflon based pipe dope for the pipe threads. If you are uncomfortable doing the work yourself or don't know how to proceed, then call your local gas supplier for help. Douglas
Sep 02, 2010 | Reliance Water Heater #6-50-GORT 50GAL...
Heater won't turn off. Wires were troubled
Shut off the gas to the heater. Bad gas valve. Gas should not be leaking from any part of the gas valve.
Oct 21, 2009 | Cozy (W352E) Heater
Gas Water Heater leaking
If the tank is fairly new you me able to reseal the leaking fittings. You will have to turn it off and drain, then remove the leaking fittings and reseal them with pipe joint compound or teflon pipe tape.
Aug 14, 2009 | Rheem Gt199dvn Heavy Duty Tankless Water...
Desa International GWRN18 Infra-Red Wall Mounted Panel Heater Logo
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
