My thermoheat 55000-75000 BTU kerosene heater acts like its warming up then wont turn on and the light blinks, I have no manual, whats the problem
  • 188 Answers
SOURCE: All-Pro Kerosene Heater
I manuafacturer has now closed down, so ALL-PRO, Master Heater, Universal, and Reddy Heater parts are getting harder to find. I have found that www.masterparts.net have all the parts I was looking for. I suggest you check them out.
Posted on Mar 06, 2009
koolbreezes
  • 540 Answers
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
SOURCE: An All Pro 60000 btu kerosene heater.
The fuel filter is clogged you need to clean it. Mine was doing same thing, easy fix.
Posted on Jan 20, 2010
hardrocko
  • 1476 Answers
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
mxc2
  • 146 Answers
SOURCE: i need a ignitor for a 150000 btu construction
You can get them at www.allpartsinc.com
Here is a link:
http://www.allpartsinc.com/Items.aspx?key=search&code=__ALLCATS__&searchval=pp200&incl_m=F
Posted on Nov 19, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Thermoheater 210,000 BTU will not run. The ignitor is working, fuel is spraying across ignitor. If fan blade is removed, unit will light? It seems to be getting too much wind from the fan blade, causi
Doug, I'm not sure if I understand completely. Are you saying that the problem existed when you still had clean 1-K Kerosene in the tank? If that is the case, I would first check the spark ignitor to ensure that it is clean and set at the correct gap. Understand that Kerosene which has been standing in the tank since last season will not be as volatile as fresh kerosene and probably should not be used. Diesel fuel, especially Diesel #2, is also not nearly as volatile as it should be. I believe these heaters should only be used with fresh kerosene or #1 fuel oil.
Feb 01, 2015 | Washing Machines
Thermoheat kerosene heater
Push the reset button.
Dec 16, 2013 | Heating & Cooling
I have a profitter 210,00 btu fires but wont light what should the pressure gage read?
I'm guessing this is a kerosene forced air heater. the pressure for a 210k pro fitter is 8.5 psi.
Jan 13, 2012 | Heating & Cooling
Parts
I would try Reddy heater parts google them and there is a whole list of places to order them from. As far as a local distributor I would not have a clue but myself if there is a Grainger store close by you I am sure that they may have parts or be able to send you in the right direction.
Jan 12, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Have a 115000 btu forced air kerosene heater.. used maybe 12 times over 3-4 years. when turned on motor is binding somehow. i maqnually turned blade and does not spin easilly. whats causing this?
Unfortunately it is the lack of use that has hurt this unit. Try using PB Blaster on the bearings and working the fan by hand until it loosens up. It will loosen up eventually, when it does give those bearings lubercation with a light oil. From running and shutting down and not using it for a while I would think that things got a little rusted up inside, this happens due to condensation forming on the warmed parts then it rusts. You can check the fuel pump but they usually are not an issue with the heaters.
Dec 27, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heating & Cooling Logo
287 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
