Question about Yamata FY14U4AD
Janome 9000 won't turn on
I broke a needle earlier and the thread jammed. I turned the power to the machine off and now neither the light nor the power will turn back on. I have taken it apart and made sure that all of the thread and needle were removed from the bobbin area. Any idea on how to fix this??
  • amandajmccoy Jan 24, 2009
    Thank you...I did try all of those things. I am thinking it is probably a fuse so I am going to that now.
    Scholar:
  • 65 Answers
The machine does not run.
1 A thread is caught in the hook race.
2 The control circuit is not working correctly. Turn the switch off and
turn it on again.
3 The machine is not connected to the power supply.
(I know duhh...but maybe your plug into the machine itself was loosened during your repairs.
Go to Janome.com and ask the professional Ask Jan, if none of these solutions work.
Hope this helps
Posted on Jan 24, 2009
I ran my Juki DDL 8700 without any fabric to test and the threads got sucked in and now the needle is jammed, when I turn the hand wheel it won't move the needle.
Loosen the needle. Once the needle is released, the threads holding it may loosen. Then gently try clipping jammed threads with tiny scissors and patiently try removing cut threads with tweezers..
Dec 21, 2017 | Juki Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
I was embroidering on my janome 9000 it jammed and went dead and won't come back on!
Be sure that it's still plugged in and not on a plug in that is controlled by a switch that got accidentally turned off.
Other than that it is likely that a fuse got blown or the power supply died. In that case take it in for repair.
Dec 12, 2012 | Janome Memory Craft 9000 Computerized...
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
Thread jams starting with 1st stitch on Bernina 160
since a needle broke, & a new needle was put in, was the needle inserted correctly, normally flat side to the back of the machine, & pushed all the way into the needle holder
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case.
if none of these suggestions help, then it's possible that when the needle broke it could have caused the machine to jump time & would have to be checked at a sewing machine shop
May 21, 2012 | Bernina Virtuosa 160
I was sewing, turned the machine off to pin something, and when I turned it back on, it jammed in the bobbin area. It will only stitch one stitch and then jams. I have taken it apart over 30 times, and...
have you tried changing the needle-
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
check the thread take up lever-if the thread come off the thread take up lever that will jam the machine up--I've had it happen to me
Sep 13, 2011 | Euro-Pro Shark 9110 Sewing Machine
Yamata FY14U4AD Logo
151 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
