Question about LG DLEX2650W 7.3 cu ft Electric SteamDryer
How to remove front panel on lg dlex2801w - LG DLEX2650W 7.3 cu ft Electric SteamDryer
2 Suggested Answers
MakeupWizard
  • 39 Answers
SOURCE: LG WD-12124RD How do I remove the front panels?
Hiya,
most machines now open from the back you will find 2 or 3 screws/bolts at the top holding on the top section if you un screw those then slide the top back slightly it should unclip allowing you to take off the top this should expose some more screws or bolts that will be holding on the front & sides, if your machine is leaking from the front you could have a leaky door seal too so you may want to check that before starting to take it apart.
Hope this helps
Posted on Apr 23, 2010
DLEX2801W won't stay powered up
I do not know that machine but It appears it is not coming up to full speed when you hold the button in. I believe there is a contact in the start switch (contained in the motor) that latches it on. It is probably something loading it down so it cannot come to speed. Possibly bearings etc. Remember this is only a guess I do not know the machine.
Jun 16, 2014 | LG Dryers
Need to remove front panel of dle0442w to get to heat limit switch
unplug the dryer,remove the top panel,remove the control panel,usually a couple of screws on the top right and left side,when you get the control panel off there are like 4 screws on the top front panel then open the door and remove 2 more screws,disconnect door switch.go here this will help you out i'm trying to go by memory and it's harder to remember how to do it,when i'm in front of it i can pull it apart no problem but this should help you out.
http://www.youtube.com/watch?v=RvbJn61d9hQ
Nov 08, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
LG DLEX2801W dryer will not turn on
Lots of possible problems.
Here are the most probable causes, from most likely to least likely:
1) The door switch may have failed or broken.
Many of these are plastic, and can break, or can even fall down inside the machine.
2) The timer may have failed, and needs to be replaced.
3) You may have a "tripped" circuit breaker in your "fuse box", wherever that is.
These are often found in the garage, basement, hall, or wherever.
4) You may have a burnt or broken wire where the electric cord attaches to the back of the machine.
Be blessed.
Mar 04, 2013 | LG DLEX2801R Electric Dryer
Electric LG DLEX2801W (steam dryer) not heating.
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2011 | LG DLEX2801 Electric Dryer
How do I get the front panel off of the LG dryer? I have unscrewed the actual door and screws around the drawer, I am trying to vaccum out the lent under behind the front panel piece.
remove the top panel screws on the back of the unit first,then the control panel in front,then the lower panel along with the front cover with the door
Nov 18, 2010 | LG DLE5955 Dryer
How do I remove the front panel of my front loading LG dryer
Open door. Remove phillips head screws at 5 and 7 O'Clock positions. Close door. Use putty knife to push in clips (2) relaeasing top. (located in seam where top meets front panel) Swing top back. Remove two phillips head screws at top of front panel. Unplug light and door switch. Tilt front panel forward and lift off bottom tabs.
Sep 25, 2010 | LG DLG5988 Gas Dryer
How do you remove the front panel on LG model # DLG0452W . I want to replace the igniter glow.
Disconnect the washer from the power source. Use a putty knife blade to release the locks of the top panel. Insert the putty knife blade in the seam between the top panel and the front panel about 2 3/4" from the edges. Push until the locks are released and lift the top panel.
Open the door and remove the 2 screws from the bottom of the door opening. Remove the 2 screws from the upper side of the front panel and pull the front panel out. Disconnect the door switch connector and remove the front panel completely.
Feb 12, 2010 | Washing Machines
Heater element-how do you change?
take puttyknife put between top and front panels about two to three inches from sides one at a time push in to release tab top will flip up two screws at top front corners pull front panel toward you unplug door switch and remove front panel then take four screws from roller and duct panel and remove from latches and unplug conector underneath set roller panel aside remove belt from will walk you thrugh the rest
Feb 23, 2009 | LG DLE2532W Electric Dryer
How to open lg dle2514 front load to clean blower and vent
Remove the 3 screws holding the top of the dryer.  Push the top towards the rear and remove top.
Remove the front control display board by removing the 2 screws and unsnapping the control panel.
Remove the 4 top screws hold the front panel and the 2 bottom screws in the door frame area.  Remove the light switch wire connector.  Tilt the front panel forward and lift up.
Apr 29, 2008 | LG DLE2514 Electric Dryer
LG DLEX2650W 7.3 cu ft Electric SteamDryer Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
