Question about Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
I have the canon 70 LiDE. it works fine, but whenever i scan a document then save it on another file, it seems to trip up the system because it prompts the above message: unable to scan. make sure there is enough space on the target disk... the only thing i can do to correct the problem temporarily is to re-install the program.. does anyone know how fix this problem...
  • Gloria Bisson Mar 25, 2009
    I have a CanoScan LiDE 600F and whenever I try to use any of the scan buttons on the scanner, I get the message: Unable to scan. Make sure that there is enough space on the target disk.
    Please help. I have uninstalled and reinstalled and still have the same problem.
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Posted on Aug 27, 2009
  • 3 more comments
  • charlie2011 Aug 06, 2011
    Worked for me just now. Great!
  • i_smurf_u
    i_smurf_u Jan 16, 2013
    thanks!
  • i_smurf_u
    great! thanks!
  • Andrea Davis
    Andrea Davis Oct 19, 2013
    Thanks so much. This freaked me out so bad. I love you!!!
  • onitamo Jan 19, 2014
    THANK YOU ! Your solution is best and easiest and it works perfect! Love you!
The problem is with the default location of the ".. Folder Where Temporary Files are Saved". In the Toolbar click on settings and change the location of the Temporary files to any other location or create a new one. This change solved my problem.
Posted on Jul 24, 2009
  • Engineerguy Feb 26, 2011
    I tried this once and it was helpful but then the problem reappeared. Solution #1 worked for me.
In Settings, change the temporary save folder back to:
"C:\Users\( YOUR USER NAME )\AppData\Roaming\Canon\TB50\"
Posted on Nov 29, 2011
  • 490 Answers
Do you have enough disk space? Delete unwanted files in your Harddisk, do a Defrag and run Scandisk. If you want the file small to be small try TIFF mode for SCanning, if Color, try JPG.
S. Mohan, India
Posted on Feb 06, 2009
  • CosmicRay99 Dec 08, 2010
    This problem is all over the internet from people who are well aware that they have oodles of disk space. It is a Canon software problem, and solution 2 works for me. I'm amazed at how many people answer this question with "have you checked your disk space?" Grrrr!!
Can not scan. Get message "Unable to scan. Make sure there is enough space on target disk". Changed default temporary disk location, have plenty of disk space.
Had this before and after a day of playing about with cleaning out the windows temp folders, I simply uninstalled all the driver and toolbox software, downloaded the latest version from Canon's site and reinstalled it. After doing a bit of research, found out it was caused by a windows update conflicting with the drivers
Dec 27, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Using Canoscan Lide 70. When trying to scan receive message "not enough room on target disk" When I reinstall Toolbox it works (for a while, then same repeats).
When you scan a picture, you send it to a "Target" folder which you can set up in your scan options or settings.
At a guess your current destination or target folder is getting to large for the hard drive that its registered on
You've 2 options, clean out the target drive or use the scan options to send your pictures to a new destination with plenty of space.
Mar 05, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
An error message when i try to scan
On the CanoScan Toolbox program bar, select settings. Then hit the Browse button next to "Select Folder where Temporary Files are Saved" and go up one level to Canon from TB50. Then hit OK. This fixed the problem for me after Microsoft Updateinstalled updated Canon drivers. It looks like the geniuses at Canon are either having you write to a write-protect folder or one that only has system permissions and then giving you a disk-full error.
Mar 25, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scanning problem with a CanoScan8600F
Hi
 go to the your scanner properties please see there your current path.. and change the the path.. select your free hardisk space..which driver you've free space.. ther only stored you're all documents...
it will work
Nov 18, 2008 | Office Equipment & Supplies
Canoscan lide 70
Head for the Canoscan Toolbox and click on "Settings".
Under "select folder where temporary files are saved", click on "browser".
Choose where you want the scanned item to be sent and then click 'OK".
This works for me.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
5,034 people viewed this question
old marine
old marine
