Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Default won't work
I forgot the password for my router and I reset it ut it won't accept the default user name and password. What do I do, please help!
  • Anonymous Jan 26, 2009
    can't even login. Even password was correct it would stay at login page
    President:
  • 1,214 Answers
Hold the hard reset button in for 30 seconds, before disconnecting power.
Posted on Jan 24, 2009
Forgot password 192.168.1.1:80 router wifi
try admin for the user name and no password, or no user name and admin for the password. also, try a hard reset by holding reset button on back for 30 seconds w/ router disconnected. This will wipe any settings you had saved. But it will set everything back to default. You could also download the manual for that model of router to find out the default username/password. Good Luck.
Nov 25, 2013 | Computers & Internet
Forget user name and password how to set up new ones
You may have to resent the router for that purpose! User name and password are usually default for each router. If you have not set up a user name or password try default admin in password section and leave user name blank. If you have set up a user name and password and forgot now then you may have to reset the router by pressing reset button on back of router for 30 to 60 seconds which brings back factory default settings for the router!
Sep 12, 2011 | Computers & Internet
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
How do i set a password
Router's password could mean 2 things. First password for you to open router's configuration page or password for you to connect wireless to your router.
Configuration's password:
-Logon to your router configuration page
-Please to the TOOLS and ADMIN Tab. You there you can change the admin user name and password. If you do not have the user name and password, please check for the default user name and password on the router's manual. If default user name and password won't work reset the router. Press and hold down the reset button or pinhole on the back of the router for 10 seconds. Then re-enter user name and password again. It should work this time.
Wireless Security Password:
-Under SETUP and Wireless Settings tab you will get an option to change the wireless password
May 21, 2011 | D-Link DIR-615 Wireless Router
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I forgot my user name and logon domain
If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port on the Router to restore the Router to factory settings.
After resetting the Router to factory defaults, use the default name and password.
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
Jul 02, 2010 | NetGear WNR2000 Wireless Router
Hughes net and Dlink address conflict
the default user name is admin and the password field should be left blank. if that does not work to get back in you will have to reset your router to factory defaults. to do this follow these instructions.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
at this point the factory default ip address is 192.168.0.1 the user name is admin and the password field should be left blank as mentioned before.
Apr 24, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wr850g will not install. Default name/password does not work. The default settings are NOT accepted. How do I get past the log in page?
a user manual is available here http://support.digidave.co.uk/index.php?_a=downloads&_m=get&_i=5 there is a reset button on the back - reset to factory settings to get back to the default username and password
see page 15 of the user manual - link above
Mar 17, 2010 | Arris WR850G Router (DHWR850G)
Forgot my user name and password
The default username for the router is admin all lower case. The default password, is blank.
Try this first - if that does not work, you will have to set the router back to factory defaults, then do any setups on it that you had before.
To perform a reset on the Actiontec - Press and hold the reset button on the back of the Gateway for 15 seconds. This will reset the unit back to its factory default settings.
Mar 29, 2008 | Actiontec GT704WG Wireless Router...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
225 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
