Question about Konica Minolta Bizhub 501 Copier
501 2803 ERROR CODE
Replaced toner concentration senser, drum dv printer cont bd and oacb
  • 3 Answers
SOURCE: Have replaced drum and toner and printer still will not work
If you refilled the drum, you will need to replace the chip in the drum
Posted on Apr 15, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
Posted on Jun 01, 2009
SOURCE: replaced drum unit and came up with error code
c-2251 - K PC Motor’s failure to turn
The Motor Lock signal remains HIGH for a predetermined continuous period of time while the Motor is turning.
Reemove the unit and try to rotate the drum and the developer gears by hand, you should be able to rotate it fairly easy.
Posted on Aug 23, 2009
FingerStrong
  • 190 Answers
SOURCE: i replaced the toner drum and i still get a
try to reinstall the printer driver software. you can download the printer driver software from your printer manufacturer's web site then restart the computer and printer.
Posted on Jun 11, 2010
Minolta ep 1030 error e1
Imaging unit toner detection failure - during concentration read operation (F8), the result is less than 1v. Replace the developer and retry the F8 procedure.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 18, 2014 | Konica Minolta Office Equipment & Supplies
Sharp mx 5111n error code f2 40
Take all toner out. Press P,*, CA, *. Go to 25. Then go to 2 automatic dv adjustment. Click kcmy at bottom and hit execute. Repeat 2 - 3 times. Then install toner and see if it works. There is a sensor in the dv unit that senses to much toner in there. Could be caused from worn out drums or dv unit itself.
Nov 13, 2013 | Office Equipment & Supplies
IAM GETTING A CODE ON CANON CLC 1150 EO20 &E0181
This is an error for the Drum units. The E020 is for toner concentration, the " 01 " is for Magenta and the " 81 " is for the concentration in the developer unit for the window sampling is below 70. Best thing to do is replace the Magenta Starter and do an initialization procedure in Service Mode. Better left to a Tech.
Jun 20, 2011 | Canon CLC 1150 Color Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
Yellow toner senser not responding
Toner sensor is located in the seat of the toner cartridge, and signal from it is transferred via the drum unit to the contacts on the sides of the drum unit and through them to the printer.
It sometimes happens, that these contacts, either the ones on the sides of the drum unit, or the ones inside the printer, get dirty and have poor electrical contact, giving this kind of message.
Try to reseat the toner cartridge in the drum, clean the contacts and re-insert the drum.
Nov 06, 2009 | OKI C3400N Single Pass Color Printer
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error code E000025-0000
1) Drum unitIs the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Good Luck
Feb 03, 2009 | Canon imageRUNNER C3200 Copier
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
Konica Minolta Bizhub 501 Copier Logo
66 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
