Question about Amana PTH123B25AJ Heat Pump Air Conditioner
My amana ptac unit in making a lot of noise...when i put it on cool and on 64 the compressor make a lot of noise...what i should do?
oscarn
  • 109 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 12 Answers
SOURCE: Have amana heat pump ac
The fan needs to be cleaned and lubbed. If this cannot be done then replace the fan.
Posted on May 22, 2011
sfender713
  • 397 Answers
SOURCE: Amana PTAC unit stopped working
I think the likely issue is that the compressor blew itself- which in turn blew the fuse. I'd speak w/ Amana if it's in warranty, if not I'd see about consulting a local HVAC- Bar that, replace the unit. It's too stinking hot to not have an air conditioner!
Posted on Jun 27, 2011
  • 3 Answers
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Posted on Nov 06, 2011
hellrayz
SOURCE: I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
The RSK is VERY specific on programing
Read the manual failing that email me and explain how to do it.
VERY VERY easy
Posted on Aug 02, 2012
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
My Amana PTAC unit is not cooling properly I just cleaned everything on it the coils and everything is still not cooling properly
check to see if the compressor on the outdoor unit is running, if so it could possibly have a refrigerant leak or faulty 4 way valve
Apr 27, 2016 | Amana Heating & Cooling
Amana ptac unit that cools four minutes and shuts off?
thermostat most likely. running to long to be safety issue.
Jun 15, 2015 | Amana Heating & Cooling
If you unplug an Amana PTAC unit and it freezes what could happen?
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
Jun 08, 2017 | Heating & Cooling
PTC073E35AXXX humming
sounds like a control transformer . No danger.
Nov 20, 2012 | Amana PTH123B25AJ Heat Pump Air...
Amana ptac- blows same temperature air whether its set at 80 or 65...any ideas?
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
Ptac fan keeps blowing
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
62 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
