Question about Canon PIXMA iP1700 InkJet Photo Printer
Removing the paper
HOW TO REMOVE THE PAPER I DO NOT HAVE THE MANUAL
  • 170 Answers
Here is a link to the Canon web page where you can download the manual for your printer.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=13364
Hope this helps,
David
Posted on Mar 13, 2009
PAPER IS JAMMED INSIDE PRINTER. HOW TO REMOVE PAPER WIHOUT DAMMAGING NOTHING.
Always remove paper in the same direction as the paper is fed through the printer. Refer to the manual if there is a paper feed button you can use, so that the printer will remove the paper on its own.
Oct 18, 2014 | Office Equipment & Supplies
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Panasonic paper jam error
Why is this posted under Flat Panel Televisions? Go through operation manual, where there is very clear guidance to remove jammed paper, with pictures. If you remove the front panel, there will be picture inside that also how to remove jammed paper. Kindly follow these.
Jul 28, 2012 | Televison & Video
13.20.00 paper jam. But there is no paper in the system. I checked from all sides but there is no paper in it. I restarted to check if the paper path is cleared but no change.
13.20.00 JAM INSIDE <LOCATION>
Paper has not moved past a certain paper
sensor. <LOCATION> can be one of the
following locations.
? TRAY 2
Remove the tray, and then check the
paper path for obstructions. Perform a
manual sensor test and observe the prefeed
sensor (PS102) status (B). Toggle
the sensor flag to determine if the status
changes.
? TOP COVER
Remove the print cartridge, and then
check the paper path for obstructions.
Verify that the top-of-page sensor
(PS103) and the media width sensors
(PS106 and PS108) are unblocked.
Perform a manual sensor test and
observe the status of these sensors.
Toggle the sensor flags to determine if
their status changes.
? REAR DOOR
Open or remove the rear face-up bin,
and then check the paper path on each
side of the fusing assembly for
obstructions. Remove the fuser, if
necessary. Perform a manual sensor
test and observe the fuser delivery
sensor (PS700) status (C). Toggle the
changes.
? DUPLEXER (only printers with duplex)
Remove the duplexer, and then check
the paper path for obstructions. If the
message persists, replace the duplexer.
Aug 18, 2011 | HP LaserJet P4015N Printer
Canon ir400 paper jamming at heater section
just remove the cartridge and remove the paper essay
if you don't know how to remove the cartridge just see the user manual booklet or download user manual from cannon website for proper model printer user manual
Apr 16, 2011 | Office Equipment & Supplies
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
Several pieces of paper fed in printer and now I have a paper jam and cannot remove the paper
...look at the printer manual to remove jams. Some time you may have to remove the difuser to get rid of them. Depending what type of printer you have. Remember you can go on line to download the manual if you don't have one available. Check if the paper is catching excesive mousture and that the roller that catch the paper have been given proper maintenance. Tks.
Jan 14, 2010 | Kodak ESP 5 Printer
Paper jammed and torned.cannot remove the paper
If paper is jammed internally, you may need to remove the rear access door to clear the problem.
1) Press power to turn off the printer
2) Follow manual to remove rear access door
3) Remove the jammed paper or any little bits that might interfere with the paper path.
4) Replace rear access door.
5) Power on
Try printing again. I hope this solution helps!
Dec 26, 2009 | HP DeskJet 2600 InkJet Printer
Paper jam
you need to remove the jammed paper, you may need to take the printer apart as much as possible to get it all out, the manual generally has instructions on clearing a jam do you have the manual do you need it?
Oct 20, 2008 | HP Photosmart 3310 Printer
Open Questions:
See all Canon PIXMA iP1700 InkJet Photo Printer Questions
Canon PIXMA iP1700 InkJet Photo Printer Logo
56 people viewed this question
old marine
old marine
