Question about Samsung Refrigerators
Samsung rf197 water goes into the vegetable drawers
There are water in the vegetable drawers all the time coming from the back of the fridge
SOURCE: Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Posted on May 13, 2009
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
  • 225 Answers
SOURCE: Water in Fridge
Hi gchives.
My own fridge had this problem and it turned out to be a blocked drain at the back of the fridge compartment, just below the cold plate. The water is supposed to condense on the plate and run down to a drip channel, and then through a tube onto the top of the compressor, where it evaporates.
On mine, the tube was blocked with gunge so the water spilled over onto the bottom of the compartment. I got a length of earth wire - the sort used for wiring UK domestic ring mains - and poked it down the tube to clear the gunge away. I then chased it through with some hot water and washing soda and it has been fine ever since.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge.
If they do not, please give me more details so I can try to help you further.
Cheers, D
Posted on Jun 30, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
jumptrout51
  • 3361 Answers
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Posted on Feb 21, 2009
I have a bottom freezer model # RB215ABBP/XAA with ice behind and inside the right-side vegetable drawer; some vegetables froze. Why?
Samsung has had this issue for a long time now. The problem is the drain in the refrigerator is clogged and leaking inside. If you remove the drawers and look back then you will probably see a rusty line where the water has been leaking and you will see water under the bottom long deli drawer.
If it has been leaking for a long time then it is recommended to replace the evap cover in the fridge section as the foam gets waterlogged and will cause future issues. If it just started the you should be ok.
There is a new drain kit part# DA82-01415A that will solve this issue.
The fridge should be defrosted for 24 hours prior so you can get the evap cover off without damage from the ice (unplugged and doors open for a full 24 hours. Longer times may be needed if this has been happening for longer then 2 weeks.)
Feb 11, 2018 | Refrigerators
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Water in the fruit and vegetable draweres
You might have the frig. temperature set too low. Set it at 38 deg. check actual temp. with gage. What happens is ice builds up in the drain tube that runs down to the bottom when the fridge defrosts therefore causing water to run into the veg. drawers. Ice buildup is preventing the water from running out at the bottom where it should. Just raise your fridge temperature a little and the problem should go away. Hope this helps.
Feb 04, 2013 | Samsung RF265AA Bottom Freezer French Door...
Water comes into the fridge from the freezer.
You have the drain from the coild froze up. The coils defrost and the water cannot run down the drain so it goes into your fridge.
This tip is all about that and how to fix it.
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
Heatman101
Jan 24, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Refrigerators Logo
377 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
