Question about GE Refrigerators
Freezer Thaw door on freezer not sealing completeley, when I close it and open fridge door it opens a little.
  • 198 Answers
Loosens screws on the top hinge and pry the handle side of the door up then re tighten the hinge, bottom of the door is probably dragging
Posted on Jan 24, 2009
  • 267 Answers
IF ITS A SIDE BY SIDE , YOU NEED A LOWER HINGE . THERE IS A CAM BUILT ON IT AND IT WEARS OUT . there not expensive and easy to do as long as you dont have water in the door . then the water line must be run through it . good luck
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
