Hi. I have a Packard Bell Store & Save 3500 320GB external USB drive with power pack. Acer Laptop TravelMate 4220 with XP Pro SP3. Connecting the 3500 hangs the laptop. I read somewhere previously that you have to connect & power up in a certain sequence, but I can't recall it. Any sequence I try usually fails - but very occasionaly it all works to my surprise. It all worked fine after puchasing about 2 years ago - just for a few weeks. Then this trouble started and I have not been able to solve it properly since then. Can you please assist?
  • 41 Answers
The sequence you plug in the hard drive shouldn't matter. I would click Start -> Run and type:
eventvwr
Click okay. When the Event Viewer loads, click Application. Do you see any errors associated with the times you plug in the drive? Also, check the System events and look for the same thing.
If I were you, I would replace the cable connecting the computer to the external drive. If that doesn't work, I would get another external enclosure and transfer your drive to it.
Posted on Jan 24, 2009
Hp simplesave not recognized xp
Unfortunately XP is no longer supported. You could try reinstalling the OS from your CD.
Jul 31, 2017 | HEWLETT-PACKARD Hewlett Packard HP...
Hi..I just want to know where can i buy battey pack for my laptop..I've been using Acer Travelmate 4220..I hope you can help me find an original one.Thanks..
I suggest you Google search for a battery for your model Acer, you can then get a price comparison from the various suppliers.
Jul 01, 2011 | Acer Computers & Internet
I have a packard bell store and save 3500 250gb and it seems that it has packed it. i need to get the files of the hard drive how can i fix it?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 10, 2010 | Computers & Internet
Hard drive for acer laptop 525 TE travelmate
You can use an external hard drive with an USB hard drive case and and connect it to your USB port
Jul 07, 2008 | Acer TravelMate 2300 Notebook
Hello i hv a acer travelmate c110tci and i hv a problem with it!
Your Acerf C110TCI will not succesfully run Vista. It does not meat the minimum requierments. It may load, but you won't like it. Stay with XP and SP3, it will be much better.
Thanks
Brian
Apr 11, 2008 | Acer TravelMate C110 Tablet PC
Problems detecting the HDD in my travelmate 331t
ribbon connection From Motherboard, Not supplying power or not enough power.
Try An external USB Hard-Drive, see if this Works.
Check Connecting pins On hard-Drive And Computer Mating Surface. Blow to remove Any Dust.
Make sure it,s Connected Firmly.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 331T Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
422 people viewed this question
David Payne
David Payne
