Drawer problem ''Paper drawer is out of order''---this is happening on both drawer 3 & 4.
  • 1 more comment
  • Trunk monkey Jan 24, 2009
    Kyocera KM4530---tried taking out paper and putting in new paper, still will not work....
  • Trunk monkey Jan 26, 2009
    It is a Kyocera KM4530. I removed both drawers from their track and there was paper lodged way in the back. I removed the paper and then noticed that a sensor had been knocked loose (possibly by the paper jamming) so I put that back together and I am still getting the message "paper drawer is out of order, select another drawer". There is no code associated with this message. My manual says to call service representative for help.
  • Scott smith May 11, 2010
    Hi There,
    What is the make and model of the machine you have? Is it displaying an error code on the control panel?
    Steve C.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
DRAWER OUT OF ORDER Copystar
You have to reset the drawer by; 10871087 and run SIM 906
You should be able to just key in the Code you wish, then hit the print key to activate.
Then use the touch screen to reset then print key again.
Posted on Feb 01, 2009
How do i fix the paper jamming which happen in my copier machine ricoh 2027at the second,third fourth drawer?
you need to check does the sensor on the drawer which is on the right side front of the drawer, does correspond with the paper inside the drawers.
Oct 10, 2016 | Ricoh Aficio Office Equipment & Supplies
Minolta di520 error code C0990
C990-C994 3rd drawer lift up and 3rd drawer elevator motor failure.Check the actuators and two motors .
Removal of the 3rd drawer:
1.Press the paper descent key and slide the 3rd drawe out to the front.If pressing the paper descent key does not allow you to slide out the 3rd drawer,insert a screwdriver or similar object trough the hole in the rear cover and unlock the drawer.
2.Remove 4 screws on the slide rails and pull the 3rd drawer out to the front.
3.Unplug 1 connector,loosen 2 thumbscrews to remove the connector board assy and remove the 3rd drawer.
4.Remove 4 screws,unplug one connector and remove the cover.
5.Remove two screws and the drive bottom cover.
6.Check the gears.
Aug 13, 2012 | Office Equipment & Supplies
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
The paper drawer is stuck on my new Samsung CLP 310
Turn the printer off. Unplug it completely. Very Carefully, roll the printer onto one side. Push the paper drawer in as far as possible, then, by grabbing the bottom of the paper drawer, and the front of the drawer with your opposing hand, slowing slide the drawer to release the pressure and slide it out at the same time. Pressure from the rollers pulling paper from the drawer will jam the paper between the drawer so tightly that the weight of the machine will act as a clamp. When your remove the weight of the machine by rolling it on it's side, you can slide the drawer out easier.
Nov 15, 2010 | Office Equipment & Supplies
Paper keeps jamming in the paper drawer 1 and the right side. I have switched to paper drawer 2 and the same thing happens. Drawer is set to letter size but keeps jamming. What's the problem?
It sounds like you have something interferring with the paper path... Look for any small pieces of paper in the paper path, staples, paper clips etc...
If you can't find any then a service call will be the order of the day!
All the best! If I can help further please contact me : johno@execs.com
Oct 25, 2009 | Canon imageRUNNER 4570 Copier
Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
Letter Drawer 1 on Model IR5020
look behind tray for paper preventing the feed rollers from knowing there is paper there
Feb 18, 2009 | Canon imageRUNNER 5020 Copier
Paper Drawer is out of order
DRAWER OUT OF ORDER
You have to reset the drawer by;10871087 and run SIM 906
You should be able to just key inthe Code you wish, then hit the print key to activate.
Thenuse the touch screen to reset then print key again.
Jan 26, 2009 | Kyocera Copystar CS-5035 Copier
Copystar 5035 - drawer 2 - we had not been using drawer 2; tried to load it with 8.5x14 paper, however, now that we are trying to use the drawer, we are getting an error message "paper drawer is out of...
Paper drawer won't open all the way and it won't copy
1. Turn the system off
2. Go to the right side of the unit and open the side panel will drop down
3. Move to the front of the machines and pull the drawer out as far as it will go, if it stops that meant there is a piece of paper caught in the take up area.
4. Go back to the side where you opened the panel and look for the lead edge of the paper, if you see it grab hold and up and towards you.
5. If you can't see the lead edge of the paper you will have to force the paper drawer out, just pull hard and the drawer and a piece of paper will come out.
6. Remove the drawer completly and then look in the paper drawer cavity for the remaining piece of paper.
http://www.websitetoolbox.com/mb/copierquestions
Dec 28, 2008 | Ricoh Aficio MP1600SPF Copier
93 people viewed this question
jasbo
jasbo
