Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
Kdl xbr326 problems with 2.06r software update
Why does my kdl 32ex700 bravia flashes green and yellow lights
After board replacement, a software update should be done. If you haven't done yet, update it with latest software version suitable to the replaced main board. Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 22, 2014 | Sony Bravia Kdl - 32Ex700 32 inch 1080P...
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
32 lcd sony bravia, will turn on but nothing else.model kdl-32ml130. how do i repair this?
According to the symptom problem is not so critical, the software needs upgrade. Today i am doing same with another model with same symptom, although updating of software is not big deal for us but i will suggest you to please contact any sony service center or expert nearby, because we do this in routine but lot of things involve like, for software update you need original USB (1GB,2GB but not higher) of Sony, and do some changes after updating in data etc, Which will make it difficult for you, So i will suggest you get it to the nearest service center and they will get nominal charges of it.
Please let me know if yo need further assistance on comment column.
Thanks for understanding.
Nov 24, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Keep getting content error when trying to stream netflix to bravia - what's the deal
download the latest software update for the tv. you can get the software update through esupport.sony.com
Oct 09, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The tv will not work
I had same problem 7/20/10 on a new sony. TV did not recognize HDMI input from Comcast box. It did recognize coax input. Mine was a software issue (my version 1.506) needed an update. Check sony site, it is posted. They are mailing me the software to update.
Jul 24, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Kdl-32s2000: t.v. turns off and light blinks 4 times
My sony Bravia KDL32 LCD had a similar problem it kept switching itself off and then switching back on after a short period of time, I dont think I had the 4 blinks though. I switched off the software download and auto update which seems to have resolved the problem so far.
Jan 31, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
KDL 32S5500 TV When left on standby overnight locks-up, hangs.
There is a Post on the Sony Support site which I hadn't previously found. Basically there is a software bug which has come about apparently due to Freeview transmission changes. In order to stop the the machine locking up disable the 'Automatic System Update' option. A Sony centre will apparently apply a software fix to properly resolve the issue, fine if with warranty period, maybe pricey if not. I will get the fix but haven't yet done so as the workaround of disabling the System Update option works.
Sep 18, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
BRAVIA TV KDL-40V2500
i had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
Sep 28, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
