Call you local Lowes and find out if they will send a repair person to fix the range. They may wish you to produce the sales receipt for the range to prove it is under warranty.
Thats what is sounds like to me- or the keypad..... Anytime you have multiple malfunctions of of the control panel, it usually is one or the other. Hope this helps. Good luck, Dennis Wayne
After a self-clean the F-1 code came on and I couldn't use the touch pad, completely dead. I read a single post from "Toughs" on your site about pushing the "Clear" button and then the "Start" button and keeping it held til the lock button lights up (takes a while) and push "Clear" again. Afterwards everything worked and was able to reset the clock and used the stove and oven.
Thank you for the solution, saved myself a $240 service call and keypad replacement, which is what I was told was needed.
I tried this on the advice of another post. It worked for me and now all of my burners are working again!
Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start"
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused. You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display. This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^&UG
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner!!!
