Question about Apex Digital AD-1110W DVD Player
Dvd player not loading
When dvd inserted, it tries to load then "no disc" message appears on screen. the player is Apex AD-1110W
  • 1 more comment
  • donde Dec 03, 2007
    When I input the DVD is says loading and then eventually it says no disc.
  • rnelson947 Jul 10, 2008
    when i insert a disc it takes forever to spin and spin and then says "no disc"
    I
  • Anonymous Jul 28, 2008
    I have the same problem EXCEPT it will play VCD abd CD just fine.
    Tried CD/DVD cleaner disc but it still doesn't load DVD.
    Any suggestions?
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
Posted on Dec 03, 2008
The same problem happened with my dvd player. i rubbed rubbing alcohol all over the lazer several times with a q-tip and still no luck.
then my buddy tried blowing in it several times, like we used to do with the old school NES system (remember those????) and it worked like magic!
Posted on May 05, 2008
I had a 5-disc cd changer that couldn't read discs, skipping from disc to disc after attempting read them. It opened it up, wiped the eye with rubbing alcohol on a q-tip, that didn't help. Then got a duster can, that high powered spray. That did the trick!!! Tried that on the Apex when it was getting bad disc and stalling on movies when it did play, it helped it play one movie about 3/4 of the way then it started the stalling again. After that it said bad disc constantly. I forgot about the rubbing alcohol trick. I'll try that in a day or so. Found a replacement dvd player on clearance so no hurry with the Apex fix for me. If the rubbing alcohol does work I'll write back.
Posted on Jan 20, 2008
The lens over the laser may be dirty. Purchase CD/DVD player cleaning kit and follow the instructions for cleaning. If that does not work then it is highly possible that the unit may need to be replaced.
Posted on Aug 20, 2007
6ya staff
SOURCE:
GPX D1816 DVD
This is a common situation, this an indication the laser assembly pickup is failing, it is far cheaper to replace the player than have it repaired.
Mar 10, 2012 | Apex Digital AD-1110W DVD Player
Apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
May 23, 2009 | Apex Digital AD-1110W DVD Player
I need a manuel,i cannot find mine
it reads unknown disc with every dvd movie we try to play
Nov 26, 2008 | Apex Digital AD-1110W DVD Player
"no disc"
try other cd's which you know it was working before. the cd you are playing might be defective wit scratches
Oct 06, 2007 | Apex Digital AD-1110W DVD Player
Manuals
Jason,
Who is the manufacturer of your player??
Sep 08, 2007 | Apex Digital AD-1110W DVD Player
My apex & aiwa
everest,
Give cleaning the lens a shot, or blowing some air inside the tray.
Aug 23, 2007 | Apex Digital AD-1110W DVD Player
Apex dvd player 1165, dvd keeps on ejecting before loading
Sounds like a mechanical problem of sorts . Hard one to call without opening and looking. Before you tear it apart I would try calling Apex Digital At 866-427-3946, as they are very good with there customers. Good luck
Jun 10, 2006 | Apex Digital AD-1110W DVD Player
Apex Digital AD-1110W DVD Player Logo
873 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
