Question about GE WBVH6240F Front Load Washer
GE washer wbvh6240fww runs normal untill it starts to drain and the pump motor makes a humming sound and will not drain. I have cleared all drain lines, filter and the motor. I also took the motor to a parts place to test and it ran put the impeller did not spin very fast. I also received a error code 70 while in service mode. Not sure if I should replace the pump or the control??
mikedurland
  • 481 Answers
SOURCE: Drain pump/motor not draining.
actually it sounds like there was or is something in the water pump (like a string or metal underwire from a bra). before replacing the water pump i would look inside it and check for foreign objects.
  1. unplug the machine, but leave other hoses connected
  2. use a butter knife or putty knife to open the front panel; at the top seam between the top panel and the front panel is 2 metal clips (about where the edges of the lid are). push these strait in to release the front panel.
  3. once the front panel is off then you should see the water pump on the right side. it has 2 large black hoses and 2 wires attached to it.
  4. take off the water pump (two 3/8 bolts) and look inside it.
some pictures borrowed from fixitnow.com, allpar.com, applianceaid.com and repairclinic.com
  • if you need to buy a new pump, then they are around $50 at repairclinic.com
  • or shop around; GE Washer Pump part # WH23X10013
  • here is a cheap one on ebay:
http://cgi.ebay.com/GE-WH23X10013-Washing-Machine-Washer-Water-Pump-Motor_W0QQitemZ170239837032QQihZ007QQcategoryZ20714QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
let me know if you get stuck
Mike
Posted on Jul 30, 2008
ithana
  • 185 Answers
SOURCE: GE washer WBVH6240; Won't tumble or spin with any kind of load but works fine empty
Hai
Check This,I think this may helps You,
Recently, our front-loading GE WBVH6240 washing machine (essentially the same as the GE WBVH6260 and GE WHDVH626) stopped pumping out water, leaving the machine filled with soapy suds. Internet research showed that the solution was to pop off the front panel, open a drain, and then take apart the motor. Fixing it took much longer than it should have, because we could not find any photos or clear instructions as to where the screws and cleavage points were. Therefore, I'm posting some instructions with photos, with due credit for the basic process to http://forum.appliancepartspros.com/washer-repair/1482-ge-front-load-washer-wont-drain.html
bpg40.jpg Oh, and by the way - ours came without any serial number or model number label on the side or, for that matter, on the back. Shame on Sears or GE - though we probably should have noted this when it was first delivered. We got the model number by looking it up in the manual, matching the drawing to the machine.
First, a word on the pump. This is a DP40-018 Hanning Elektro Werke design - you won’t find that on the Internet easily. However, a search led me to hanning.de, which sells this assembly under the Hanning DP40 label. I suspect you can find a reseller eventually, for the pump itself; the rest of the assembly is unlikely to ever be damaged. The pump is made in China but we’re assured of Quality German Supervision (those of us who have relatives with Volkswagen and Mercedes cars are no longer convinced that German Supervision and Quality belong in the same sentence).
The working parts of the machine are accessible once you’ve removed the front panel. Underneath the front of the machine, if you bend down far enough, you can see three white-painted screws. Use a good, standard Philips screwdriver on these (#2 in our case). Get a good amount of pressure on the screws before turning because GE was foolish enough to get paint into the working part of the screw (that is, the cross-hatch), and you don't want to strip these. They are not that hard to get out, but again, you don’t want to strip them. Take out the three screws, pull off the panel, and you can see everything.
The pump is very close to you, on the right-hand side, right in front. First, get a big bucket - preferably several - and open up the drain valve (righty-tighty, left-loosey, so go LEFT, or counter-clockwise, to open it). Gallons of water will shoot out along with whatever rubbish is in the machine - pebbles from your young child, emory boards from your wife (or from you), marbles, coin batteries, lots of small change, etc. This in itself may solve your problem! but we might as well check the pump.
The pump screws are invisible unless you've taken off the hoses from the pump. There are two of these, and if you take them off before you drain the tub, you will have pretty well damaged the inside of your washer. Try to catch the water that comes out when you take off the hoses. My system is to use a locking pliers (vise-grips) to compress the two parts of the clip together - set the vise-grips so the two parts of the clip will just about touch each other. That will give you enough wiggle room to slide off the hose, gently, while holding the clip loose. Do not let the clip come back together over the hose. Gently open up the vise-grips once you're out of the washer and drop the clamp somewhere. Remember which clamp belongs to which hose (there are two hoses). Also remember which hose goes to which part of the pump. You should really be writing this down or something as you go. Photos of inside-the-washer are difficult to get.
Now, you should be able to see one of the screws. It's a bit of a job to get the screwdriver vertical over the screws, but you can do it. Do not try to hold the screwdriver at an angle; you really do not want to strip these screws and you don’t have to. They are not in very tight, and should come right out. One screw is pretty far to the left; the other is roughly in the middle of the pump; they are both on the far side of the pump and screw it down to the floor of the washer. Don’t try for the screws that hold the two parts of the pump together. The pump includes the drain-pipe! It’s all one assembly and it’s sold that way by Hanning. You can see it in the illustration at the top of this page. The pump is held in place by fairly firm supports that, when you look at it from the front of the washer, are behind the pump/pipe assembly.
To get the wires off, -- remembering which side each color wire is on! -- squeeze hard and pull carefully, working each terminal off, but without using so much force that you might break something or, when it releases, slam your hand into the sharp metal edge. Pull at the terminal, not at the wire - you don't want to break these, either, unless you like using solder guns in tight spots. Now you can gently push the pump/pipe assembly back, so that the white stubs on the drain-pipe clear the little rubber washer things, and when it’s free carefully lift it out of the washer.
Okay, now the pump is out. First, find the three visible screws that hold the motor to the pipe assembly (two of them are visible in the first photo, partly unscrewed), get a laundry marker, and mark the plastic where the screws go in so that when you re-assemble, you don’t have to figure out which holes they go into. Then separate the two parts of the pump - the motor and the rest of it - by undoing the three screws. We kept using our #2 Philips but a #1 might fit better; the screws came right out so it wasn’t an issue. And look what we found: a safety pin blocking the impeller (the moving part) from moving! No wonder the pump was warm. (If the pump is not warm, that indicates no current reaching it. However, on this washer, the pump does tend to get blocked more than anything else.)
hanning-pump.jpg A new pump will run you at least $170, probably more, from GE, so it’s well worth taking it apart and fixing it yourself, especially with service calls at $70 per hour.
I tried to get some of the lint out, with moderate success. This is a badly sealed pump and frankly I'm not impressed by the filter design, either. Someone got cheap in the engineering process and did not consider that owners do not want to take their pumps out every two years. Be careful with what you put into the machine!
When you re-assemble the pump, make sure you put the screws back into the holes that have threads.
Putting everything back was easy enough - be careful about pushing the white stubs into the black washer things (for the drain-pipe), and you may find the wires a little short, but it’s easier than getting it out. I had a photo of what the pump looked like before I took it apart, and now you do to, so you can easily put it back together the right way. The hardest part of getting everything back together was wiping up the water that spilled from the hose, and then getting the outer lid back on without someone to hold it in place.
Thank You
Posted on Sep 11, 2008
  • 5 Answers
SOURCE: ge washer is not agitating or spinning
change the timer.
Posted on May 28, 2009
  • 942 Answers
SOURCE: no spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Posted on Jul 08, 2009
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Posted on Sep 04, 2009
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Motor hums but won't start
chances are the pump is blocked as well and unable to spin
Nov 03, 2013 | Dishwashers
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Mar 13, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My ge front loader washer model number wbvh6240fww wont't rinse and makes a humming sound during the rinse cycle
I'm hazarding a guess- the sound MIGHT BE from the machine attempting to drain the water but cannot, therefore not going on to the rinse cycle. Just in case this is the problem follow my general (pre-typed!) guidance notes on filters and motors ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 03, 2011 | GE WBVH6240F Front Load Washer
Washer runs until it gets to the Rinse cycle and stops... You can tell it wants to work because there is a faint humminb sound, but doesn't.
If the washer will agitate it's not a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction.
Jan 10, 2011 | GE 3.2 Cu. Ft. 14-Cycle Super Plus...
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge front load washer won't go into rinse cycle.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Ge wvsr1060a2ww washer does not spin or agitate
first look to see if this is a belt drive. If not look for a coupler(round black rubber piece with three holes, three plastic fingers from both sides going in it) from the motor to the gearcase. The motor sit between the pump and gearcase, it will pump out, but not spin.
Nov 08, 2008 | GE WVSR1060A Top Load Washer
GE WBVH6240F Front Load Washer Logo
132 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
