Question about Asrock M266 Motherboard
Memory upgrade I was given a computer. When I got the computer it only had one sdramm memory chip. It was 128kb. I have no Idea of the manufacture of the motherboard. The only information i can find on the board is a number. M266. I am presently running two 128kb 133mhz sdr ships. So I only have 256k of memory. I would like to upgrade to at least 512k ddr. I am not sure though of how much memory the board will take. It was suggested to me to get a 512kb ddr chip, speed 166mhz. What do you suggest I do. I am running windows xp. When I got the computer. It had windows 2000 onit. I formated the hard drive and put windowsxp on it. It runs okay. However it is running slow, and windows has to keep warning me that Iam running low on memory.
  • 32 Answers
According to ASROCK who seems to be the manufacturer (please check the picture against your motherboard to be sure) it will support up to 2GB of DDR266 (in two 1GB sticks). Note that some motherboards can be "picky" about memory even though it's all supposed to be compatible. I recommend taking it to a shop so that they can try the memory in the machine before you buy it. Also, you can only run SDR or DDR chips, NOT BOTH. Just want to make sure that you don't fry your motherboard!
Personally, I'd recomment getting two 512MB sticks to get a total of 1GB. More than that is probably overkill for an old computer, although less than that and you'll probably wish you had more. More never hurts, but it doesn't help if you don't need/use it.
Posted on Jan 24, 2009
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
Dc5100 processor upgrade
Two Netburst based Processor cores on the SAME chipset?
Get outta' here!
When did they come up with that?
The HP Compaq dc5100 Desktop PC uses an Intel 915GV motherboard chipset.
Since we know that the Northbridge chip, of the motherboard chipset; handles the Faster capabilities of a computer;
i.e., Processor, Ram Memory, and HIGH-speed graphics; let's look at the Intel 915GV chipset,
No sir/ma'am.
The Intel 915GV motherboard chipset only handles Single Core processors;
Intel Pentium 4,
Intel Celeron,
Intel Celeron D.
(With a 533MegaHertz Front Side Bus, or an 800MHz FSB)
The Celeron D is NOT a dual core processor,
"The D suffix actually has no official designation, and does not indicate that these models are dual-core. It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers) Unlike the Pentium D, the Celeron D is Not a dual core processor."
Yeah, I know. I'm just a 'Ray of Sunshine'.
You know you can pick up a motherboard pretty cheap nowadays, that WILL support the lowly Pentium D, for not much money.
Problem is you will need to replace Ram Memory also.
By the time you get a motherboard chipset that supports dual core Processors (CPU), you are going to be using DDR2 Sdram ram memory, instead of the DDR Sdram ram memory you are using now.
OK, Motherboard, CPU, and Ram Memory.
Oh, the Power Supply. Won't do either.
240 Watt unit, or 300 Watt unit?
Back in the day those Power Supply's were made, Power Supply manufacturer's were 'fudging' the actual maximum rated Wattage.
True Wattage was more like 60 to 70 percent of what was stated.
SOLD more Power Supply's.
240 Watts?
Simply divide by 10. = 24.
For 60 percent, take 60 times 24. = 144 Watts
70 percent? 168 Watts.
300 Watts?
60 percent is 180 Watts.
70 percent is 210 Watts.
I wouldn't try to run a Barbie doll with that low a Wattage, of Power Supply. (Barbie doll? What?)
Need at least a decent 350 Watt power supply, from today's manufacturers.
80 percent constant duty cycle, for most good units; or higher.
Max out the Intel Pentium 4 CPU.
4GB's of 533MHz DDR Sdram ram memory.
(PC4200, or PC4300. Depends on the manufacturer as to how they name it)
By the time you spend that much money, you may as well buy another Motherboard, Processor, Ram Memory, and Power Supply.
Yes, may as well buy a better computer.
I know. Quit trying to cheer you up.
Around here we have Craigslist, and Ebay, for two places.
Could pick up a better computer, for around the same money, as you would pay for all the upgrade parts above.
Which is better? Upgrade the Processor, or upgrade the Ram Memory/
For the better 'Bang for the Buck', upgrade the Ram Memory.
The CPU (Processor) has a built-in cache.
L1 cache, and L2 cache. (Newer CPU's have an L3 cache)
The Cache is a small memory area for the CPU.
It is the FIRST memory area the Processor (CPU) reads.
This is because it operates at the same frequency rate, as the CPU does.
(Frequency rate = 'Speed'. Operates at the same 'Speed')
Next inline is the Ram Memory.
Ram Memory -> typically, operates at half of the Processor's Front Side Bus. (FSB)
This is why upgrading Ram Memory is a good idea.
It isn't so much of getting Ram Memory, that operates at a higher frequency rate ('Speed'), as it is to have MORE ram memory.
PC3200 compared to PC4200.
4GB's of PC3200 is better than 2GB's of PC4200.
(DDR Sdram at 400MHz = PC3200)
Moving on............
Motherboard chipset:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
The motherboard chipset for your computer, consists of a Northbridge chip, and a Southbridge chip.
{Motherboards that support the Intel Core i technology, (Core i3, Core i5, Core i7, etc), do NOT use this motherboard chipset technology. Neither do some of the AMD CPU's }
As stated previously, the Northbridge chip handles the Faster capabilities of a computer;
Processor (CPU), Ram Memory, and HIGH-speed graphics.
The AGP technology, and the PCI Express technology; ARE high-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics; is NOT high-speed graphics.
The slower capabilities of a computer are handled by the Southbridge chip.
1) PCI Bus / Integrated Graphics.
(Another term for Integrated Graphics, is OnBoard Graphics. A term that seems to have gotten lost.
It explains better; ON the motherBOARD )
2) IDE Bus
3) SATA Bus
4) USB Bus
5) Ethernet
6) Audio (Sound)
Look to see what the Northbridge chip is, as I have shown you; and you'll get a good idea of what Processor (CPU) support is.
For additional questions please post in a Comment.
(I get tired of looking on websites, that just say NO, and do not explain why )
Mar 06, 2013 | HP Compaq dc5100 PC Desktop
Dell computer.5 yrs.old. Very,very,slow.What can be done? Have dial up internet service. Also, what does memory upgrade mean?
There's nothing you can do about your internet speed, dial up is dial up and is known to be slow. If you want fast internet then you would need broadband.
A memory upgrade would speed up the overall performance of the PC. For example: the computer may take 5 minutes to fully boot up and programs taking time to launch. This would not fully resolve but help it to be more responsive.
A memory upgrade is always recommended by me. I expect that your computer can be probably maxed out to 2GB of memory.
Jul 19, 2010 | Dell Dimension 2400 PC Desktop
How much memory can you install onto a macbook I would like to upgrade to 1TB
Memory or hard drive, they are two VERY different things. Memory is used to store running programs only while the computer is on - is super fast - and gets erased when the computer shuts off because it requires electricity to maintain a state. A hard drive stores information long term.
That being said, memory can be upgraded to whatever the mother board supports, usually 8gb max these days (Good luck finding the memory chips to fit in there though). Most people will get two 2gb chips - as most motherboards have only two slots for memory. Some have more. You will need the correct speed of chips however that your motherboard supports. you can't use 10 year old chips in a modern computer, they aren't the same design.
The hard drive can be upgraded to 1tb, and more, and you can buy external hd's for more convenience.
Apr 19, 2010 | Computers & Internet
ACER Aspire AX1200-U1510A: What mother board and socket is in this computer? AM2, AM2+, or AM3
you have given the memory chip number and not the computer model the chips you have are 533 MHZ DDR so I would suggest you click on start go to my computer right click on properties and it will list the chip set. here is a web page you can go to to see the memory you have.
Feb 11, 2010 | Acer Computers & Internet
Drives compatibles
Any drive will work with your machine. Hitachi, Western Digital, and Seagate are all very good drives. With the memory, match the make of the additional memeory to the memory currently in the machine. Sometimes two different manufacturer's memory chips will conflict with each other.
Jul 31, 2008 | Computers & Internet
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Soltek KT-600-R and SP2
Have you tried a Motherboard Bios Firmware Upgrade? It should be readily available on the Manufacturers Website.. There are a number of diagnostics you can do to pin-point the actual malfunctioning component, rest assured everythings stable with the softwares being used and the OS environment is virus/spyware free! you can 1st upgrade the Bios to the most latest (Non-Beta) version.. If that doesn't help, try a single 512mb Memory Stick, one by one and notice if that helps with the (BSOD) errors..
Mar 15, 2008 | Computers & Internet
Asrock M266 Motherboard Logo
65 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
