Question about IBM 3500 Typewriter
Keys don't match what types. Letters type other letters.
I dug out our old IBM Wheelwriter 3500 by Lexmark today and my toddler banged on it a while while I did something else. Now, when I went to use it, the letters on the keyboard did not match the letters that printed. And we can't find the manual, though I remember keeping it for years and years in one place. It must have something to do with the code, in green. Does anyone have a user manual that can help me reset the whole typewriter back to regular matching keys? Unplugging it and turning it off and on doesn't help. Thanks.
  • IBM Master
  • 3,594 Answers
Check the connectors from thr PC board to the keyboard, if they are OK tren try this hold the code key press and release the "L" key type 001 release thecode key. If this works you need a keyboard to repair it'
DickyO
Posted on Jan 24, 2009
  • Dick O Reilly Mar 26, 2009
    danielabruna;
    Tour printwheel is damaged or missing a spoke the 2 vertical lines are the hammer face. Get a new P/W.
    DickyO
  • Dick O Reilly Oct 14, 2009
    Try this remove the batteries turn off the machine for a min. or so turn it on everything should reset. THE MEMORY WILL CLEAR.
    DickyO
Change keyboard mode. Not typing correct letters
Hold down the "code" key, the one to the left of the spacebar that says "CODE" on it, and hit the "L" key (the one that says (Lang) on it. Should be back to normal.
Sep 21, 2015 | Lexmark Wheelwriter 3500 Typewriter
Why does my typewriter carrier spontaneously fly to left when typing?
You are most likely at the R. margin with auto return on. Hold the code key and press "R" key.
DickyO
Sep 01, 2015 | Lexmark IBM Wheelwriter 3500 Typewriter -...
When I type, the keys move but they do not stike the ink ribbon.
You probably have a broken solenoid cap. You will need to order the cap but I do not know who has a video or instructions to do it.
Apr 08, 2014 | IBM Wheelwriter 3500 By Lexmark Electric...
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
IWhen i turned it on it only types half the letters/numbers etc
If it is only typing the top half of the letters the platen may not be fully seated in the side frames, push down firmly on both ends of the platen it should snap into place.
DickyO
May 11, 2010 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Only some of the keys work.
The keyboard is probably bad contact Geo. Beyers Co. 1-800-392-8085.DickyO
Apr 09, 2009 | IBM Wheelwriter 30 Typewriter
MANUEL
The l. row of keys say save play and delete, hold the save and press 01 to 99 as an address release and type when finished press save again, To play use the same procedure with the play key.
DickyO
Jun 05, 2008 | Lexmark Wheelwriter 3500 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM 3500 Typewriter Logo
543 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
